DIY: MT shift knob with CVT
Old Jan 1, 2020
DIY: MT shift **** with CVT
So, a DIY guide for this is fairly dependent on what kinda spring you get. That'll, for the most part, help determine how long to make that sleeve. I will advise that, if you take this on, you have to have some sort of machinist mindset. The parts list I have listed below are for my setup. If you decide to take another path, this will, at the very least, serve as a reference guide of how to make sure it operates appropriately.
Here's the research/design phase thread. Kinda abbreviated, since I did a lot of research, then posted a thread about it. That thread started as a DIY guide, then I made this one and turned that into a research thread
Also, please forgive the wall of text.
Estimated time(s):
  • Design: Depends on you. Fine tuning my assembly took a few months. Lots of it was waiting on parts to arrive, researching different parts. Yeah, took months.
  • Fabrication: Less than an hour's worth of work.
  • Installation: 15-20 minutes
Tools needed:
  • Dremel (or similar type of tool)
  • Drill (drill press highly recommended, unless you're really, really good with a handheld)
  • Threaded fastener driving tool (e.g. allen wrenches, screw drivers, etc) -- highly dependent on the fasteners you use
  • 1/4" Drill bit
  • 14mm reamer (or a visit to a machine shop to have them do the tube fab/modification for you)
  • File rated for the material your tube
Materials/Parts needed:
  • A tube, of sorts.
    • ID must be as close to 1"/25.4mm as possible, not smaller, unless you have a way to bore the tube out to 1" or greater, but as close as humanly possible
    • OD, try and keep it below 1.125"/28.575mm. Up to 1.25"/31.75mm will fit, but it'll start to grab the OEM shift boot.
    • I purchased a filament wound sanded carbon fiber tube because it was fairly cost efficient, dimensions were pretty much exactly what I was looking for, and, well, it's carbon fiber. Why the hell not?
      • I initially used a delrin tube from McMaster-Carr, but found the tolerance was way looser than expected, the ID was smaller than 1", and that's how I learned about the OD issue. That was fun to make fit /s
      • January 2024 update: The bottom of the carbon fiber tube finally gave way after 4 years. Not enough to shoot the **** assembly into space, but enough to make me re-think the carbon fiber thing. It was still functional, but would "pop out of socket" all the time. I then decided to go for an aluminum tube I off of Amazon. I personally purchased a 25mm ID/28mm OD one, but I would highly suggest going with 25.5mm or 26mm ID. The 25mm, I had to use a rubber mallet to get the Raceseng adapter in, then I had to do a whole **** ton of alignment to make sure the tube and the ID of the Raceseng adapter were parallel enough with each other so the whole thing didn't bind upon use. Using a larger diameter and making sure the Raceseng adapter mounting holes are diametrically opposed from each other will alleviate all of that headache of aligning it all. Truth be told, I got the 25mm one because I didn't think 0.5mm would make that big of a difference, but it sure as hell does.
  • A Raceseng non-threaded adapter for a BMW (P/N 081201). You'll have to bore this out to 14mm to ensure it slides on the shift lever adequately. Remove the set screws, but save them. You can use these to measure actual thread pitch for the next part needed
  • 2-M6x0.8 fasteners. I'm 95% sure they're M6x0.8, but they may be M6x1.0. Like I mentioned above, use the setscrews from the Raceseng adapter to measure the thread pitch at Home Depot or similar. Length is dependent on the tube you use. I used 10mm long (shortest I could source locally) and I cut them down the the 6mm I needed for my carbon fiber tubed setup.
  • A 8-10mm M6x0.8 set screw. Again, I'm 95% sure they're M6x0.8, but they may be M6x1.0. This is kinda dependent on the type of shaft collar you buy. I'd buy the 10mm if I were you.
  • A single setscrew type shaft collar for a 14mm shaft. Remove the setscrew and put in your drawer of random fasteners. You'll be replacing it with the 8-10mm one.
  • A spring.
    • At least 0.6"/15mm ID
    • Less than 1"/25.4mm OD
    • About 1.75-2"/44.5-50mm extended length
    • Make sure it has the ability to compress 0.7" in your tube assembly. If you have time, buy this last and use your actual setup to measure out what length tolerances you have
    • I'd recommend a 15-25lb spring load.
    • Literally an OEM one out of a Nerf Retaliator (or find one on Nerf blaster modding websites) work perfectly. I used to mod Nerf guns and I had springs laying around. This spring weight was enough that I could kinda rest my hand on the **** without depressing the whole assembly, but also not so strong that I felt like I was fighting the spring just to shift into gear.
  • Shift **** of your choice. If you're going the Raceseng adapter route, it uses a 3/4-16" thread pitch. Non-Raceseng ***** with that thread pitch are kinda hard to find, particularly ones with no gear indicators on them (Unless you want to fool people into thinking you have a MT). Those ***** are really nice, just pretty damn pricey. Just saying.
  • A small zip tie. To secure the boot.
  • [optional] A shaft/pipe with a 14mm OD that's at least 6" long. I used a 1/2" (I think) galvanized pipe that I put into my drill and sanded down and polished to get it close to 14mm OD, poor man's lathe style.This just helps with dry assembly and fitting everything together. If you go this route, make sure the shift **** adapter is able to slide up and down without much resistance, if at all any. If you buy it from the store, it won't slide freely. I found this one on amazon that's just shy of 6" for pretty cheap. It might work pretty well.
  • [optional] Lubricant of sorts. A thin layer of lubricant (grease or dry lube like graphite) on the inside of the Raceseng adapter and/or the OEM shift lever outer tube could help with operation of the assembly.
How it do:
Removal of requisite panels (sorry, no pics yet -- this guide should help you visualize it all)
  1. Remove the two "boomerang" pieces on the left and right of the center console. They're held in with.. 4(?) clips. Use a pry tool or a thin flat head screwdriver under one far edge and pry upwards to release one clip. I'd recommend starting from the back. The 3 back clips are at more of a downward angle and the top ones are more of a horizontal angle. Set those aside.
  2. You'll see 2 screws exposed on the top/back of the next panel. Remove those screws and pull upwards on the shifter trim panel. The first time you pop those loose, it'll be hard. Gently pry with a good amount of force. Disconnect the 3 electrical connectors (brake hold, parking brake, & eco button) and set that trim aside.
  3. Use this guide to remove the CVT shift ****
  4. There are 4 clips holding on the shift indicator panel (console cover, as it's called in the above guide). They're not easy to pop off, but there is a trick I found, but it's easier said than done on the front two. You see those orange clips holding it down on the back 2 clips? Push horizonatlly on the back of them while pulling upward. They'll pop right off. You can try and find an angle on the front two. I ended up losing one clip and breaking the hole it mounts into, so mine is held in by 3 clips now. lol. Lift that bad boy up and out, but don't forget to disconnect the electrical connection first.
  5. Congrats, you should now be staring at a bare shift lever.
Fab of the sleeve
  1. Take your tube and cut it down to 60-70mm length. If you aim for the 70mm length, you run the risk of the bottom of the tube catching the forward part of the shifter assembly, but literally nothing filing on the backside (forward end with reference to the car) can't fix. It'll kinda prevent you from shifting into park.
  2. Insert the Raceseng adapter into the tube to make sure it fits. Pray it's kinda snug. Remove the adapter and place alongside the tube. Line the top of the tube higher than the bottom set of set screw holes and mark the centerline of the set screw holes. You're going to be drilling holes there (if you hadn't figured that out yet), so make sure you have clearance above the hole you're about to drill so you're not ripping the edge of the tube. I set these adapter mounting holes approximately 6mm down from the edge of the tube. Take that one point and make another mark 180° from this hole. Basically marking the other endpoint of the diameter of the tube, 6mm (or so) down.
  3. On the opposite end of the tube, make a similar marking. Again, I used 6mm from this mark to the end of the tube. Make another mark 0.7"/17.8mm above that. this mark doesn't have to be super accurate.
  4. Now, the marks from step 2, you're going to be drilling straight through both walls of the tube with a 1/4" drill bit. The drill bit going through should be riding an imaginary diameter line perpendicular to the tube. These two holes should line up with the lower 2 setscrew holes on the **** adapter. This side will be referred to as the top of the tube
  5. Drill out the 2 marks from step 3 with a 1/4" drill bit. You're gonna end up "milling" the space between the drilled holes to create an oval channel. The elongated set screw from the shaft collar will be sliding up and down in this channel, so make sure it allows that to happen. If you make the channel too wide, you'll end up with excess rotational play in the completed assembly. Try and keep this channel as tight as possible with respect to the set screw OD, but still allowing it to move within that channel. What this accomplishes is limiting up and down movement of the assembly. Upward movement limitation -- the bottom of the channel -- is more important than downward, since that's what's gonna prevent your shift **** from launching into space.
Installation (or dry fitting on your dummy shaft):
If you went the route where you can test your assembly out (which I recommend, anyways), these steps will help. It'll also help you visualize how you're going to install this piece on your car.
Here are all the the pieces of the shift assembly, sans shift ****, with an aforementioned dummy shaft:
  1. Insert the shaft collar inside the bottom of the tube and loosely thread the setscrew through the channel and into the shaft collar. Ensure the set screw does not protrude past the ID of the shaft collar just yet.
  2. Slide that assembly onto the shift lever shaft
  3. Install the shift **** (not pictured) onto the adapter and slide that assembly onto the shaft and indie the tube. Install at least one of the adapter mounting screws. Washers are used here because I have not cut these screws down yet.
  4. At this point, the shift **** should be resting on the center shaft. Use the **** to barely depress the center shaft/button. Try and limit that button depression to 3mm at most. Ensure the shaft collar is at its bottom-most position, and tighten that set screw. You can adjust this later as installation of the shift boot may shift the contact point a bit. Note: if you made yours like mine and the channel lines up vertically with the adapter mounting holes, make sure the setscrew faces fore-aft on the car. If anything, you'll want to make sure the adapter mounting holes face fore-aft, otherwise you'll have troubles shifting. You can use Loctite on the setscrew for extra reassurance that it's not going to slip on you, but I've not had it vibrate itself loose. Jan 2024 update: that setscrew never failed or vibrated loose over the 4 years I've had this installed so far without using Loctite. I made sure that thing was reasonably tight during installation. Basically tight as you can get it without fear of stripping that set screw out. That said, make sure that long set screw is of quality materials. It's the one thing that makes this entire thing functional so yeah, crank that bitch down.
  5. Remove the screw you installed, remove the adapter, and insert the spring inside the shaft.
  6. Slide the adapter/**** assembly back onto the shaft and screw it down. You will likely have to shift into D or L/S to install the forward screw.
  7. Test operation by pushing down on the **** and shifting back and forth. Things to look for:
    1. Ensure you cannot shift out of park without depressing the ****.
      1. When shifting out of park while fully depressing the shift ****, see if you can feel anything catching when pulling the lever backwards. If you do feel something catching, it's almost certainly the front-facing bottom edge of the tube. I'd recommend filing away at the forward-facing bottom edge of the tube, being careful not to mess with the side with the oval slot. You can realistically file away as much material as you want, but for safety's sake, I'd ensure the front/bottom of the tube is still below the top of the shaft collar with the whole assembly at rest. Something like this:
    2. Ensure you cannot shift into reverse, park, L or S without depressing the ****.
    3. Ensure you can take out the key while in park. If you cannot, you have to adjust the shaft collar upwards as the button is being depressed too far.
    4. Spring resistance. If it's too light for your liking, find a stiffer spring. Too stiff, lighter spring. This Goldilocks spring is gonna be the most fun to find.
  8. With everything tested properly, it's time to put your center console back together. Hold the shift adapter assembly at the adapter mounting screws and remove the ****.
  9. Grab the shift position panel/boot assembly and snip the zip-tie holding the OEM boot to the shift ring. Toss that chrome plastic sucker.. somewhere.
  10. Invert the boot, and install over the shift adapter. The opening of the boot is going to be larger than the OD of the adapter, so you'll have to get creative to make it look pretty. Once you get that figured out, zip tie it snugly.
  11. Reinstall the shift position panel and tuck the boot nicely.
  12. Hold the adapter at the mounting screws and screw down your shift ****.
  13. Test operation once again per Step 7. This time, you'll want to check one more thing. When in S/L, the center shaft will be lower than the contact point of the **** (by about ¼"/6.35 mm). Make sure it's not too wobbly, unless you really don't care. That's why the spring is part of the adapter assembly.
  14. If everything is good to go, reinstall all the panels.
  15. Sit back and revel in all your hard work. lol
__________________________________________________ ________________________
Some notes here:
  1. I decided on the Raceseng **** because the way the shift lever sits, the inner "button" shaft will be well inside the ****. I wanted to keep it at close to stock height as possible, or lower, and it looks like I accomplished just that.
  2. If you go for a standard **** with an M10x1.5 thread pitch like every other Honda MT **** on the face of the earth, the base of the **** will sit, at it's lowest point, right around the top of the inner button shaft
Old Feb 5, 2024
Re: DIY: MT shift **** with CVT
2024 update: the carbon fiber tube finally gave way at the very bottom of the oval hole that the shaft collar set screw traveled within. It still worked, but popped out of place all the time. I swapped it for a 25mm ID aluminum tube I snagged off of amazon:
Amazon Amazon
25mm is a hair tight (I had to use a rubber mallet to get the the raceseng adapter into the tube), so I'd opt for
26mm ID unless you can find a 25.5mm ID 26mm ID unless you can find a 25.5mm ID
xRiCeBoYx
Customize your car
Feb 28, 2022 11:05 PM
ProAc_Fan
Apr 15, 2013 07:47 PM
RHCP0801
Interior DIY
Apr 25, 2006 05:18 PM
soltex
Nov 17, 2005 02:45 PM
RSXtypeIvtec
Sep 25, 2003 12:05 AM
