Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
what else can I do when changing timing belt/water pump?
Old Mar 11, 2015
ashleyre's Avatar
ashleyre is an unknown quantity at this point
Hi, first time poster, first time Civic owner. I have a 2000 Civic with 110K miles on it for my everyday high mileage wear-and-tear car (original owner garaged it for years.) I have to take it to a shop because hand/wrist problems make it hard to do the work myself. It's time to change the timing belt and water pump (estimate is just under $500). Since most of the expense is in labor and the mechanic is already popping off belts and covers, is it a smart move to get these things done at the same time? What might it do to the cost? I'm assuming they'll be working inside the engine bay, not pull the engine out. BTW I'm having the work done in Richmond VA.
  • replace PS, A/C, and alternator belts
  • replace valve cover gasket, camshaft and crankshaft seals (shop says there's an oil pan gasket leak; estimate just under $400)
  • replace tensioner
  • adjust the valves
Really appreciate your help. Thanks!
Old Mar 11, 2015
mikey1's Avatar
Re: what else can I do when changing timing belt/water pump?
yes i would do all of that except the valve adjustment,
unless its absolutely nessessary, which i doubt
if the thermostat is original i would replace that also while the system is drained
Old Mar 11, 2015
ashleyre's Avatar
Thanks! Why not work on the valves?
Old Mar 11, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Since the car is 14 years old, if it were mine and I planned on keeping it and planned on putting another 100K on it, I would have them check the valves and also replace the upper and lower radiator hoses. Already off on one end anyway. Only OEM dealer parts only. If aftermarket parts, reuse the OEM. If you are having the work done by an INDY, carry dealer parts to them or work out a deal and make sure you see them before they install them.
sharp66
31
Jun 12, 2022 08:45 AM
Jigee
May 9, 2015 11:18 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
markp94
Apr 30, 2015 09:19 PM
CivicVoz
Apr 16, 2015 08:07 PM
