00 Civic Si Intake and Exhaust install. What else do i need?
Looking at installing a KN cold air intake and apexi WS2 exhaust on my civic si. Its the canadian SI model so it only puts out 127hp. Its my daily driver and im looking for a little more power. How much HP can i expect to gain with an intake/exhaust mod? Is it worth the ~$1000? Any comments would be appreciated. Thanks
Re: 00 Civic Si Intake and Exhaust install. What else do i need?
Keep in mind that's 127 rated HP at the crank, not the wheels. That means you're looking at about 100-110 hp to the wheels, less if you're running an auto tranny.
An intake/exhaust system will give you negligible power.. Probably a 5hp gain from all that.
Sucks, but it's the truth.
edit: I'm looking at a Honda Tuning Magazine article where they dyno a D16Y8 before and after bolt ons.
Baseline was 106whp
Weapon*R intake brought it to 109 (small gain from 4500-5500rpm, and again above 6000rpm, but otherwise tracked pretty steadily with the baseline)
GReddy EVO2 exhaust brought it to 112 (same gain from 4500-5500rpm, but a tad bit more high end power starting at about 5500)
I'd expect similar results from the K&N/WS2 setup
Verdict: worth it? prolly not. Is it still fun? sure.
Baseline was 106whp
That is sobering, anything else we can do for more hp?
Baseline was 106whp
Baseline was 106whp
It's deff not worth spending $1k on those parts for a d-series. especially if it's not putting out a lot of power. For $1k you should be able to find a decent LS swap and have a lot more power and more room to grow.
toastyghosty
32
Dec 26, 2001 02:03 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
