KMS Intake Manifold Thread #2 *Continued*
Old Jul 3, 2003
  #121
cwick187's Avatar
cwick187 is an unknown quantity at this point
My friend and I just messed around with the VAFC settings and it made a diff. in the mid and hi end loss. I'm more confident now that once I get the dyno tuning done, it will produce more power with the proper tuning.
Old Jul 3, 2003
  #122
tcostello3's Avatar
tcostello3 is an unknown quantity at this point
Originally posted by djmota
I agree Grey. To me using a square design for the IM just doesn't make sense to me. Now I'm no engineer but I Have a basic grasp on what air does. I think that making the air enter straight down and bouce off a flat suface reduces velocity and increaces turbulance. The runners being on the side...I would think... would have to suck what they need from the square chamber in the middle. Which is Ok Up to a point, when the engine needs more air and can't get it. Hence the loss above 5500-5700 rpm. The stock one on the other hand is not as bad as I once thought. It makes the air hit a curved bump in the bottom to split it and have it go up the side. The runners on the stock one start low in the chamber just off of the curve and then run up and to the side of the head. Sure Its plastic but That choice in material is based more on manufacturing costs than air temp or performance. Tooling on a cast piece that involved would have costed a fortune.
Now don't get me wrong I REALLY want this to work and I'm willing to do whats neccessary to get gains from this piece but not only will tuning with a cam gear have to make up for the loss, it will have to make gains that are worth while. Thats alot to ask for from a few degrees of cam timing advance or retard. To me this manifold is looking more and more something for a forced induction application. I hope it works out fro us in the end.
Copy the dimension..dump it into AutCad and fix it...Shoot it to a CNC shop and you're there?
Old Jul 3, 2003
  #123
RedDragon333's Avatar
but thats the point if this part was made to work with FI platforms for fullly tuned platofrms he should have stated so rather than telling us the manifold he dynoed gave 7hp to an LX.
Old Jul 4, 2003
  #124
tcostello3's Avatar
Very true...If most people had seen a croos section of the IM compared to a croos section on a stock IM maybe we could see that he;s trying to push air through a square chamber rather than a "directionally chareged set-up"
Old Jul 7, 2003
  #125
Pharoh's Avatar
Bobaganoosh!
Don't much really care if this IM will offer the potential for more NOS since the pussies here in Ontario banned the stuff...All I care about is turbo...I want to make damn sure there is some hope for this motor before I swap it out...I like to keep what it came with. I have 4 grand (cdn)burning a hole in my pocket that I may use for a K20A3 (SiR-Can, Si US) that I found in Montreal. I was gonna shell out another grand for the A2 (TypeS) but discovered that the A3 has lower compression hence, better turbo results...
If this IM is legit even with the extra parts and tuning (of course) I will do it stat! I would love to get what I can outta this D17 before I give up on it...Besides, if all else fails I can probably sell it to one of the 4dr's in the local group here and get the A3.
Old Jul 10, 2003
  #126
SlammedBlueEM2's Avatar
All Eyes On Z
Dynos w/ cam gears @ least...
Old Jul 10, 2003
  #127
cdmx's Avatar
nice avatar.....didn't someone say they need a reground camshaft
Old Jul 10, 2003
  #128
Stone's Avatar
Stone is an unknown quantity at this point
yeah i definatly want to see some numbers for an EX thats been tuned with an AFC. It would be the deciding factor.
If it only makes power with a turbo, then no, ill wait for the turbo. but if it makes power before the turbo goes on, I would buy it first, in combination with an AFC, because eventually I would want it once I got the turbo anyways.
tuned numbers please!
Old Jul 12, 2003
  #129
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
YAY!
I actually notice more torque and a deeper sound!!! cant wait til my turbo gets here... 2 weeks and counting... it took me 7 hours to put this thing in!!! here are some pix.
people with vafc.. what are your settings with the kms manifold?
Old Jul 12, 2003
  #130
RoBBUsaF's Avatar
Old Jul 12, 2003
  #131
RoBBUsaF's Avatar
Old Jul 12, 2003
  #132
RoBBUsaF's Avatar
gauges.
i did this yesterday...
Old Jul 12, 2003
  #133
GideoN's Avatar
GideoN is an unknown quantity at this point
Look awesome RoBBUsaF!!!
Old Jul 12, 2003
  #134
cdmx's Avatar
thats alot of gauges!!!!!!!!!!
Old Jul 12, 2003
  #135
Jodster's Avatar
Post Whore General
I think the tach is too big. You need to get a smaller one. I would look better that way like DC5@EM2 did.
Old Jul 12, 2003
  #136
RoBBUsaF's Avatar
yea.. that tach i have i got free... if you wanna buy me one ill put it in...
Old Jul 12, 2003
  #137
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
maybe im an idiot, but what exactly is the point of covering up a tach with another tach?
Old Jul 12, 2003
  #138
having the shift light? Looks good by the way
Old Jul 13, 2003
  #139
Maverick's Avatar
Maverick is an unknown quantity at this point
Just installed mine, now have a tapping noise coming from somewhere around manifold...obviouly i did something wrong or omitted something. i do not have the far bolt in yet,closest to the driver side because i could n't find anyone that has any...could this be the culprit...what else would cause this? thanks robb and chad for you help thus far.
Old Jul 13, 2003
  #140
RoBBUsaF's Avatar
i just used the old bolt.... i got a big washer and hondabonded and locktited it... try that...
Old Jul 13, 2003
  #141
cwick187's Avatar
Actually, you need a screw thingy that screws into the head and also has threads on the other side of it so you can tighten a nut on to it....I'm not sure if that makes sense, but if you take the bolt that came out of the stock manifold to a hardware store, you should be able to find it....Just call me and maybe I can explain it a little better.
Old Jul 13, 2003
  #142
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
How long did it take you guys to get your Intake Manifolds ? I ordered mine almost month and half ago and still didnt get it ? Why is KMS so slow on sending these things. No feedback from them no updates. Damn..
Old Jul 13, 2003
  #143
RoBBUsaF's Avatar
like 2 months...
Old Jul 13, 2003
  #144
cwick187's Avatar
The reason it takes so long is because John is very busy...I personally seen his shop and there is all kinds of Honda and Acura engines and parts he his working on for other people. You will get your mainfold, you just have to be patient. If your really worried about the status, give him a call: 770.652.3538
Old Jul 14, 2003
  #145
5PEED EX's Avatar
Thanx..
Old Jul 14, 2003
  #146
Maverick's Avatar
thanks chad, i'll head up to the honda dealer today to get one, or some auto/hardware store if they don't...just glad i got this thing on before the turbo got here
Old Jul 14, 2003
  #147
RoBBUsaF's Avatar
i dont understand.... what screwy thing? the old one i used was fine... am i fu(ked?
Old Jul 14, 2003
  #148
cwick187's Avatar
When i installed the IM I couldn't put the bolt in because it was too long...I couldn't get it in the hole (HAHAHA) because the new manifold's chamber was in the way.
Old Jul 14, 2003
  #149
RoBBUsaF's Avatar
so how was i able to use my old screw and it worked fine and tightened all the way??? HMMMM???
Old Jul 14, 2003
  #150
djmota's Avatar
maybe they fixed the problem on yours and later manifold by either moving the air box a bit or shrinking it. Gotta luv custom parts. hey cwick187 have you got the cam gear yet? if so how'd it work out?
