KMS Intake Manifold Thread #2 *Continued*
Old Jun 17, 2003
CarbonFly's Avatar
The other thread was getting too long. Lets get a fresh start.
Get the Manifold HERE
OLD KMS Thread
Old Jun 17, 2003
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Fly,
Thanks for starting a new thread. I don't know about other people but if so many people want to get this dyno why not contribute. I don't mine contributing if it is a $30 or $50 to get this thing dyno; and I'm not even thinking about buying it. Think about it, if there are 30 people interested then thas one dollar each or about $1.60 (USD) for the $50.
Old Jun 17, 2003
slystad810's Avatar
So they have it on their website, are they done producing them or what?
edit: nm thats for 6th gen Civics.
BTW I see a nitrous injected D17 with a CF valve cover at the top
Old Jun 17, 2003
CarbonFly's Avatar
That's the naturally aspirated KMS 7thgen Civic.
Find out more here.....
http://www.7thgencivic.com/forums/sh...ight=kms+civic
This motor has been totally balanced, and blueprinted.. everything lightened.
Port and polish, pistons, oversized valves, block guard, 500 lift cam, individual throttle bodies, coil pack, clutch/aluminum flywheel, oil pump, haltech, rods, basically everything that can be done to the D17 without using forced induction has been done to this motor. It does also have a 100 shot of nitrous. This package runs anywhere from 5,000-8,000 dollars.
They expect 250hp to the wheels from it.
Old Jun 17, 2003
nightkids1's Avatar
Initial D!!!!
any one have newer pics of it on there car???? the other pic was to small.
Old Jun 17, 2003
runner1738's Avatar
why does it say on their website for 2000 - 2001 civic aren't they different, is it just a typo or is it not the one for our 7thgen civics?
Old Jun 17, 2003
djmota's Avatar
its just a typo on the site. heres a link to a comparison pic i took stock vs. KMS
linky
Old Jun 18, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
hmm ... would this intake manifold give as much gain as say.... a header? T_T;;; ... I dunno ... is it worth it ?
Old Jun 18, 2003
CapYoda's Avatar
Escaped Convict
ah no I wouldn't compare it with a header.
although they're both manifolds.
heh.
not in our application anyway.
Old Jun 18, 2003
IronFist's Avatar
Who has it installed and has done a test drive?
IronFist
Old Jun 18, 2003
djmota's Avatar
I finished the install but havn't started it yet...i'm doing this all at work on my breaks.
here are some more pics
installed
there is another pic w/o the cai in the gallery. I'll take it off the jack stands, reset the ecu and start it later tonight.
Old Jun 18, 2003
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
Is anything else needed along with this IM ? As far as upgrades (i'm not talking about I/H/E, pulley and cam gear).
Old Jun 18, 2003
RedDragon333's Avatar
no its a straight bolt in
Old Jun 18, 2003
nightkids1's Avatar
Initial D!!!!
installed
thanks you so much for the newer pics man, i know i bugged alot.
anyways you need to come on down to the next meet so i can take a look at that in person.
Old Jun 19, 2003
Grey's Avatar
DIY King
The mounting plate is too gawd damned thick! They copied the OEM, but the OEM is plastic! How much does that thing weigh compared to the stock one?
Old Jun 19, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
I wanna know what kinda gains you think you got from it!! then again I think we all do. Man that thing looks soo much better than the stock plastic manifold.
Old Jun 19, 2003
djmota's Avatar
Well I thought of your ongoing wieght reduction obsession when I was doing the install and wieghed the stock one along with all the brackets and hardware that are not going to be used, against the KMS one... and I lost the paper that I wrote the results on But the difference was about 1.5 lbs KMS being heavier.
I drove home last night and was hoping to be able to "feel" the difference....... but I didn't
I thought that maybe my throttle cable needed to be adjusted to get wide open when the pedal was pushed all the way.... I gave it the brick on the accel pedal test and checked the throttle body....no adjustment needed
The car runs/idles fine and strong, but it just doesn't pull like I remember it.
I'll do G-tech runs with it this weekend and compare it to the runs I did before the install and see what I do or do not get.
Old Jun 19, 2003
Grey's Avatar
DIY King
OKay, 1.5 lbs isn't bad. Still though, lighter is better IMO. Maybe it doesn't pull as much since it's such a short runner length? The shorter the runner length the more power it will produce in the higher rpm's. You should see an improvement in the higher rpm's, but a decrease in the lower rpm's. If you usually drive within the lower rpm's, then you'll think it's slower. You need to dyno it to make sure though. That G-Tech meter is good I guess, but you need to set everything up the same way each time to get a good result. Good luck! I hope you gained some ponies... Then again, it's the E/T that matters most IMO. What good are ponies without the lower E/T?
Old Jun 19, 2003
CapYoda's Avatar
Escaped Convict
who cares about ET? lol.
and weight?
bah I say to both. heh... jk. sorta.
if this thing flows more and allows more hp/torque in the higher end.. its not for me then...
hopefully you get some results though.. at least a good shift of the poewrband upwards so when you do run that quarter mile or punch it.. you're doing it faster.
I care about the low end quite a bit. I hate having to rev to 4k just to get the car moving.
next car I get is a torque machine. so I dont have to be like grey and be so obessive about weight.
Old Jun 19, 2003
R1Style's Avatar
Wow that's really disappointing to read.
I hope you gained something out of this. Let us know how the G-Tech runs do.
Old Jun 19, 2003
I know, i thought you'd get a pretty good gain that you could feel. Maybe the computer has to adjust the extra airflow out. Hopefully your g-tech will show some improved numbers
Old Jun 19, 2003
nightkids1's Avatar
Initial D!!!!
lets hope so.
Old Jun 19, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
yeah more low end torque = better 1/4 mile times
since most of the quickness of a 1/4 mile time is made in
the first 60 feet
Old Jun 19, 2003
runner1738's Avatar
you say its a straight bolt in does then mean it can be a DIY or should you take it somewhere for the install?
Old Jun 19, 2003
yea it can be a DIY, thats how he is installig it.
Old Jun 19, 2003
5PEED EX's Avatar
I ordered mine today. I also had a question, is IM ready for nitrous, or do I need to drill/bore anything ? I'm not that informed on this IM that much. And also, do I need to tune the airflow once I put the IM on or ? I am planning to get my Cam Gear dyno-tuned as soon as I get it, I thought maybe I need to do something with IM also ?
Old Jun 19, 2003
runner1738's Avatar
I think the gains someone said are like 7whp, but Im still not decided on it,but if it is something that I can do myself then ill get it, since there arent any shops here. But with I/H/E and IM then we should actually feels gains right?
Old Jun 20, 2003
cdmx's Avatar
im a lil depressed...I was hoping for a..."OMG i love this thing my car is fast now!" :-P
Im just gonna get my Throttle body bored
Old Jun 20, 2003
nightkids1's Avatar
Initial D!!!!
yeah me to, but felling something and dynoing it to see numbers are differnt.
Old Jun 20, 2003
GideoN's Avatar
GideoN is an unknown quantity at this point
I feel the same. Still waiting for others to install their's and their opinions.
RedDragon333: When you get yours, I would love to see it!
