Has anyone removed their intake resonator?
Old Apr 18, 2003
civicex2002's Avatar
civicex2002 is an unknown quantity at this point
Lightbulb Has anyone removed their intake resonator?
I used to have an AEM CAI but I was too worried about sucking in water. So now I have the K and n factory replacement filter. It seemed to help a little. Now I removed the intake resonator so its just the box with the filter in it and now it seems even better. Can this harm anything? The air is getting filtered but I figure it may just get dirty faster. Couldn't be any worse than a CAI sittin low to the ground?????
Old Apr 18, 2003
PunkingCivic's Avatar
I need TP for my bunghole
The Computer used this to determine the fuel to air ratio.
I'm unsure if it will harm anything.
Old Apr 18, 2003
Xplocv2k1's Avatar
myspace.com/misterwarren =]
Xplocv2k1 is an unknown quantity at this point
hmmm. . . .on ur cai . . try a air bypass filter . . that'll help
Old Apr 18, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
It will not harm anything. It is what it is...just a resonator to make it a bit quieter.
It did however take air from the battery and headlight area....with it removed it will
mostly be sucking radiant engine air heat.
Old Apr 18, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
it'll sucking hot air ...... it's better use a hose if you do not want the resonator
Old Apr 18, 2003
YS's Avatar
YS
my getto DIY CAI .. but i use the resonator
better response, colder air
Old Apr 18, 2003
YS's Avatar
YS
Old Apr 18, 2003
YS's Avatar
YS
Then i used this
Old Apr 18, 2003
YS's Avatar
YS
Then after couple a month, the pipe holder/bracket was broken ... NOW i use the air Duct with OEM Air box .....
i'll post pic soon
Old Apr 18, 2003
IronFist's Avatar
Originally posted by YS
Then i used this
How did that Racer Design one work? It looks like it would bring in a lot of air, plus it looks like it picks up air coming straight in from right under the front of the hood. Did you get any gains from it?
Thanks,
IronFist
Old Apr 18, 2003
7thGenerasianCivic's Avatar
Don't think you really needed to worry about your CAI sucking in water...bypass valves don't work...you once had cold air sucking into your engine, and now you have hot air sucking into your engine...might not be as good as what you had.
Old Apr 18, 2003
YS's Avatar
YS
Thanks,
IronFist
better than factory setup
Old Apr 18, 2003
Bartkat's Avatar
Rubber hose, inside polished tube, with intake in FIPK heat shield, with K&N filter in stock filter box.
Name:	stock airbox with tube smallest.jpg
Old Apr 19, 2003
YS's Avatar
YS
do you have BIGGER PICTURE ?? what's the size of the rubber hose? where did you get it? i just use Vacuumm hose and it's not big enough ......
what did you use to connect the pipe to the stock air box?
Old Apr 20, 2003
IronFist's Avatar
ttt
Old Apr 20, 2003
GreenDemon
Guest
Posts: n/a
LMAO that's ghetto!! FUNNNNNY as hell, but still, whatever works.
Old Apr 20, 2003
crewzing civic's Avatar
crewzing civic is an unknown quantity at this point
Then i used this
Where did you get that kind of intake from? Ive never seen ram air like intake for our cars?
Old Apr 24, 2003
YS's Avatar
YS
Racer Design
Old Apr 24, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Dont remove the intake resonator. Sure it sounds nicer, but your gas mileage and hp will decrease.
I know because i've tried it for a couple thousand miles.
Old Sep 28, 2003
ceddy's Avatar
ceddy is an unknown quantity at this point
AKont remove the intake resonator. Sure it sounds nicer, but your gas mileage and hp will decrease.
why will removing the resonator cause the car to lose gas mileage and hp?
is it because the air being sucked in is too close in the back of the engine and sucking hot air as suppose to sucking cold air from near the headlight? i thought the resonator just made it less noiser?
wut if a tube was installed like wut others did and air was beign sucked in was cold??
Old Sep 28, 2003
player's Avatar
i have had my resonator off for a couple of months now, i love how it sounds, **** HP, but seriously i doubt it actually decreases it, and u r not harming anything, your engine is breathing better this way, plus now your engine bay is so empty that alot of air circulation will be going on, so not all will be hot air.
a friend of mine with a wrx told me to use dryer duct tube and direct it to somewhere cold, that would be a good idea.
Old Sep 29, 2003
ExOrCizT's Avatar
ExOrCizT is an unknown quantity at this point
yea i got mine off also... it sounds alot better and i havent noticed any difference in power or Gas milage... i mite cut up a vaccum tube and hook it up so it gets colder air that is intill i can afford a Racer's Design one =D
Dani1993
Jul 24, 2015 09:02 AM
hoofboy
Jul 17, 2015 04:27 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
Ccoop87
Jul 9, 2015 03:26 PM
