COLD AIR INTAKE HAS A HOLE IN IT!!!
Old Jan 10, 2003
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
S2000 Engine
My cold air intake pipe has a hole in it, i just found out, so i had to put my whole stock intake system back on!
Dammmniiittt, im so mad should i get a new free one from the company?
Old Jan 10, 2003
Bartkat's Avatar
Where is the hole? How big?
Duct tape? BTW: You can run the stock intake just fine with just the filter box, without all that resonator box and stuff.
Old Jan 10, 2003
slammed2k2's Avatar
its on the second piece, the one that makes it a cold air...my pinky finger can fit in the hole, and ya i can use duct tape but why should i have to? it looks like it was rubbing up against something down there, and after enough time, it got through it..
ya i know u can run it, but i didnt want the no resonator sound, i dont like it ne more, i rather be safe and have it all back to stock!
Old Jan 10, 2003
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
What kind of Cold Air intake was it? Not an ebay one was it? How long did you have it in?
Old Jan 10, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
What I would do is get a little piece of sheet metal, and form it with a ballpeen hammer or soft mallet of some sort, you would probably even bend it with your hand. and just make it nice and flush with the curve of the intake and solder it on. if it rubs out again just warm it up and take it off and do it again. Just be carefull with the soldering so you don't melt the intake and you should be fine. If you aren't good at soldering J.B Weld would work but more of a one time deal.
Don't know if thats something you are interested in but thats what I would do. cheap fix too
Old Jan 10, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
Brand?
Old Jan 10, 2003
xian's Avatar
Honda > Nissan
xian is on a distinguished road
If its the InJen CAI, I can see that happening. InJen provided a piece of rubber to attached to the cold-air extension because it does rub against the fenderwall and a piece of metal. I had to used duct tape to secure it correctly because it slide around a bit.
Email the manufacturer and ask about warranty.
Old Jan 10, 2003
yess24's Avatar
yess24 is an unknown quantity at this point
If it's AEM CAI, then I have the same problem, but not as severe as yours. I found it before it become a hole. Ok, the detail: the damaging happen at the lower pipe. Basically, if you look carefully, the metal hook that secure your cr battery, the L-section of the hook at the base of battery platform will stick out about half an inch or so. And the AEM downpie is pretty close to the end of the hook. as car move, the pipe vibrate and rub again the hook. AS time goes on, the pipe will be degraded till a hole is there. I found out fine before a hole is made through. And I wrap the end of the hook, and the degraded area of the pipe with normal black electrical tape. so that when they rub, two pices of rubbers are rubbing.
Another solution will be, u just need to cut stick-out section of the hook by about 1/8 in, that should provide more than enough clearnace to prevent the rubbing.Hope that help.
Old Jan 10, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Dang! I gotta find a solution for this before my brand new intake develops some sort of hemorrhage!
Old Jan 10, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I am wondering if you couldnt take it to a muffler shop or a machine shop and have them repair it somehow for you by welding or soldering in a piece.
Just a suggestion.
Old Jan 10, 2003
Bartkat's Avatar
Send it back, get a refund and buy a K&N. They fit.
K7N INTAKES FOR 7TH GEN CIVIC
ORskier
May 7, 2015 04:54 PM
JDock
Dec 5, 2001 11:52 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 25, 2001 09:38 PM
808specifxz
Nov 17, 2001 10:39 PM
Hobby2K
Nov 9, 2001 04:08 PM
