D17 Y8 Injectors
Old Dec 9, 2018
7thgenshifter's Avatar
7thgenshifter is an unknown quantity at this point
Post D17 Y8 Injectors
My car: 2003 honda civic D17a2 1.7 v-tec manual trans
what do i do???? I am swapping my p.o.s. D17 plastic intake manifold for a Y8 aluminum manifold found on a Honda Civic year:2000 (D16). Ive done all the fab work i just need help with injectors.
Do I use D16 injectors and D16 fuel rail? or do i retro fit my d17 injectors w/ fuel rail? and how do i go about this? I have read many things about using the stock injectors by using Y8 original grommets and 2 o-ring on each side? Would it be better to use d16 injectors?​​​​​​​
D17+Y8
Old Dec 9, 2018
GolNat's Avatar
Prelude Owner
Re: D17 Y8 Injectors
There is a thread about this somewhere.
Seems like you have found the thread? Did you read it?
https://www.civicforums.com/forums/1...2-ver-2-a.html
Old Dec 10, 2018
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
you can use the d17 injectors with the extra o rings and top hat adapters. I have done it in the past...it works just fine.
I'm currently running FIC 1000cc injectors for a d16 and the stock d16 fuel rail on my d17.
LeVally411
Bolt-on Engine Performance
May 18, 2019 07:16 PM
DGerus10
May 1, 2010 04:04 PM
mr jones
Jan 11, 2009 10:59 PM
d17acivic
Engine Swaps
Jul 29, 2007 01:48 PM
DriftR
Oct 30, 2002 11:02 PM
