No place for Vaccum hose to go
Old May 24, 2014
majikman's Avatar
majikman is an unknown quantity at this point
Daughter traded for a 2001 Honda Civic EX from what I can tell it has a 2003 V-Tech 1.7 motor in it. Head Gasket was bad so replaced gasket and had head machined, replaced, etc, put everything back together but have an obvious vacuum line that I can't find a home for. When start car the RPM's go from 70-up, back down, repeat. Once I plug that hose/line up the car runs fine, but I have searched high and low and can't figure out where that line goes to. Googled over and over and can't find a diagram that has the same set up and shows that hose. It is a preformed hose that comes off the bottom of the air intake manifold on the drivers side.Can anyone point me in the right direction. I am totally stumped!
Old May 24, 2014
Re: No place for Vaccum hose to go
I can't see it either! Got pictures?
PCV, or brake booster hose?
Old May 24, 2014
majikman's Avatar
Ezone, I don't have a picture-car is not here at the moment-had to take it into a shop to do a few things. Am pretty sure its gotta be something to do with the vacuum system- as soon as I plug up the hose it runs fine. Will try and get a pic when I get it back
Old May 24, 2014
May as well have them look since it's there.
Old May 25, 2014
majikman's Avatar
They can't figure it out either! They are looking for vacuum diagram but can't find one.
Old May 25, 2014
PCV hose connects to.....
Old May 27, 2014
majikman's Avatar
Had daughter go take some pics at shop and attach one on here. The hose with the bolt stuck in the end of it is the one I can't find a place for. Any help would be appreciated as Hondas are new to me.
ID:	86676   Click image for larger version
ID:	86677   Click image for larger version
ID:	86678   Click image for larger version
Old May 27, 2014
Hard to tell where that comes from.
Seems like it may go to the PCV valve on the side of the block....See an earlier pic.
Here's some more
I don't have a real 7th gen car here to look at.
Old May 27, 2014
majikman's Avatar
Yeah that would help if I had another one to look at. Will keep searching. Car runs fine as long as the line is plugged but can't be good for it!
martinsmartin
Aug 15, 2015 07:34 PM
USCGBM
Aug 12, 2015 04:22 PM
Tdmnds
Aug 5, 2015 04:23 PM
breanna_17
Jul 21, 2015 04:01 PM
silentz
Jul 9, 2015 08:16 PM
