Finally able to afford more upgrades
Old Jan 25, 2013
2005CivicDX's Avatar
2005CivicDX is an unknown quantity at this point
Alright need some advice with exhaust system, exhaust manifolds, intakes, turbos. And what else I could do to my 2005 Honda Civic DX. The engine is D17A1.
2001–2005 Honda Civic DX/LX/VP
Displacement : 1,668 cc (101.8 cu in)
Bore and Stroke : 75 mm × 94.4 mm (3.0 in × 3.72 in)
Compression : 9.5:1
Power : 115 hp (85.8 kW, 117 ps) at 6,100 rpm
Torque : 110 lb·ft (15.2 kg/m, 149 Nm) at 4,500 rpm
RPM redline: 6,750 rpm
Rev-limiter : 7,200 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-2 MPFI
Old Jan 26, 2013
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Re: Finally able to afford more upgrades
Well what is your budget? I'll give you some ballpark figures for things that are brand new
Cold air intake: 200
Headers: 200
Exhaust:600+
K-Pro: 1100
K-Swap: 4000+
Turbo Kit: 3000+
It all depends on what your goals are and what you can spend. A turbo kit tuned at 10 psi can get you 170+ horsepower
bashea
Sep 15, 2015 04:59 AM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
krazykoncepts
Sep 8, 2015 09:02 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
