Header Install
Old Dec 26, 2009
racer's Avatar
racer is an unknown quantity at this point
Header Install
Hey dudes !!! I wanna put some sick Strup headers on my 2008 Si with a KZ023 2.0L engine. How long should it take this backyard mechanic guy that I trust to install it or how much should I pay him ? Is it a hard job to do - its probably a tight fit right ?
Old Dec 26, 2009
sl33pyriceboi's Avatar
Re: Header Install
its an easy job. u just gotta jack up the car unbolt like 10 bolts and swap out for new headers.
how much you pay him is different with different locations. for example, here in CA, it would cost you prob no more than 75$ and about an hour of time.
Old Dec 26, 2009
unTuned's Avatar
Re: Header Install
yea there isnt much for mechanical work involved. you unbolt it from the downpipe and the engine, so its definitely only about 10 bolts or less, then just put the new one on, bolt it up. just make sure the guy does an ecu reset and let the car turn on and idle for 10 minutes without touching any pedals so it can relearn the new ratios.
i put my own header on last summer and it was my first time ever doing it and i only had basic tools. it took me under an hour so he should have it done easily in under an hour. you should just pay him whatever a standard mechanic hour costs where you live. where i live its 100/hr and that is very expensive. id guess about 80-100ish.
Old Dec 27, 2009
racer's Avatar
Re: Header Install
Thank-you so far 4 the info guys ! It is quite helpful & you guys responded right away - awesome ! If anyone else has a response - GIV 'er !
Old Dec 28, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Header Install
Simple and easy till you strip a bolt... then your *@#(&$@(#*&$@(#*$&!(@*&$#)@!*$%!($!!!
Old Dec 28, 2009
unTuned's Avatar
Re: Header Install
haha yes! very very true.
or until you break the head off of a seized bolt.
Old Dec 28, 2009
rednek's Avatar
rednek is an unknown quantity at this point
Re: Header Install
Don't be fooled, this is a more in depth job than just 10 bolts, trust me. Depending on the tools he has and if he has a lift, and what he knows about the car, it could take anywhere from 2 hours to easily 6.
http://www.8thcivic.com/forums/engin...h-install.html
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
