Where can I get OBD-II software?
Old May 14, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Is it something I can get off one of you guys? It's for a 2005 DX coupe.
Old May 14, 2006
no only the dealer can reflash it.
Old May 14, 2006
DeX's Avatar
DeX
Canadian, Eh!
No I mean where you can get diagnostics for your car and fine tune stuff.
Old May 14, 2006
oh. if you just want to read CEL engine light codes, there is a cheap $30 code reader on ebay that works great. if you want something better, goto the auto parts store and pick up an obdII diagnostic unit. they can be upwards of $500 tho. If you want something that actually controls how the car works like vtec engagement, fuel trims, etc then you want apexi vafcII (vtec), safcII (non-vtec) or greddy emanage.
Old May 14, 2006
DeX's Avatar
DeX
Canadian, Eh!
hmmmmmmmm............so what do the $150 units do? Just read codes? I wanted to do quarter mile times and display fuel per gallon and stuff.
Old May 14, 2006
just read codes and some expensive ones look at sensor info. if you want something for speed, rpm, 1/4, hp, etc get the apexi rev/speed meter or something similar.
Old May 18, 2006
DeX's Avatar
DeX
Canadian, Eh!
I was talking to the guys on www.mp3car.com and apparently it's not hardware dependant. You get the same hardware, but it's all in the software to be able to read and tune certain things. So I can just buy the regular reader and use the software they're using to get all the readings I want.
brags
Oct 2, 2015 05:53 AM
juror
May 26, 2015 06:35 PM
civicsrule16
17
Jul 19, 2002 10:40 PM
pinkytoe
Jun 13, 2002 10:53 AM
