Crackling sound from intake
wats up fellaz...it was raining soooo much today, and i was driving, and i have a Cold air intake...and i started hearing crackling noises, and it would intensify when ever i pressed harder on the throttle...i quickly pulled over and made it into a shortram...and it started crackling again...but after 5 mins, it stopped....btw..i dont have a bypass thingy...is my car in trouble or wat???...anyone ever had that?
Greatly Appreciated!
Drunken Master-7thgen Ninja
rain with CIA= BAD. if you can still drive it then its not hydrolocked. what kind of crackling? loud, soft, sharp? help me out here. and put a shield on the filter
Did it die when you went threw a puddle? Mine did, and bamb took forever to start,then had white smoke and a loud *** ticking. Took it to the shop, they said i bent a few things in the engine and bassically needed a new one. So i opt'ed for the K20 instead. So yeah you could be screwed
holy ****...
mine was still driveable...and i didn't go through puddles or anything..it was just raining and there was just a lot of water everywhere..after the crackling..it drove fine...no sounds at all..no other noises...drove it for like 30 miles...then came home and posted this..
take to mechanic immidieatly tomorrow. seriously. i would. and don't freak out, it could have just been vibrations of intake against other parts. tell how it goes, and good luck
better yet, throw back the factory air box as temporary until problem is fixed/solved.
goodluck. hope you didnt break any internals. iver heard stories of ppl dishing out major bucks because they damage a rod or piston was it? due to cold air intakes sucking in water
yeah that thing acts just like a straw! lol mine ran fine too. but then i found out what was really wrong lol. GET A DAMB AIR BYE-PASS VALVE IF YOU GOING TO KEEP THE CIA!
My car does that at certain psi of boost. Its running rich when my car does it. up to 8psi its fine, than on hotter days, higher boost makes that noise. BUt not even all the time, just occasionally.
Im not sure what it is in your car. But mine does a loud cracking noise, repeatedly. Drives just fine though.
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
