Question about resizing exhaust
Old Apr 27, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
I was wondering if anyone has ever resized the inlet of a muffler from 80mm to 60mm. The custom shop said they can make it smaller and adjust it down, is this okay?
Old Apr 27, 2005
Vantage's Avatar
Vantage should not be trusted
its fine, i dunno about mm diameter, but i had my piping shrunk from 2.25" to 2", to get a cat on it to pass smog. This will hurt ur performance tho.
Old Apr 27, 2005
How come? wouldn't it just be like the smaller size inlet? I'm going to be going from 3" down 2.25, how bad will it hurt?
Old Apr 27, 2005
Vantage's Avatar
3"?!??!!? im hoping u have a turbo to be runing that big of exhaust piping, cause that size piping on any car that doesnt have huge power is just MURDERING ur torque and horsepower... ur 1st goal should be to get rid of that size piping and change EVERYTHING to 2.25".
re-reading the original post... Is your Muffler size 3" or ur piping 3"... if the muffler is 3", and piping is 2.25"... and yes making ur muffler smaller to fit the piping would be VERY smart, u wont see any power gains, but u can still use the muffler. If u have 3" piping... get rid of it.
Old Apr 27, 2005
No i don't have 3" piping, I knew not to ever run that unless I have Turbo, but the pipe was a steal and couldn't pass it up, cause the shop told me I could resize the inlet of the muffler. Its the Tanabe Tuner Medallion. So it will be like I just but the 60mm?
Old Apr 27, 2005
Does anyone think this will be a problem or should it work fine now that I'm going to resize the inlet to 2.25?
Old Apr 27, 2005
Vantage's Avatar
it will work fine man.
Old Apr 27, 2005
scatman's Avatar
Still in the game...
you'll be fine, i ran 2 1/4 in my EX for yrs....its the perfect diameter
Old Apr 27, 2005
You think the muffler will look funny on the car, it doesn't have a body kit on it yet. can it tuck up there so it doesn't hang down and see the entire muffler.
Old Apr 28, 2005
Will the muffler tuck up underneith the bumper or will it hang low and look bad?
Old Apr 29, 2005
Vantage's Avatar
all depends how u get it mounted. at shops then can weld it on any angle u choose( within limits tho), so just be there when they are installing it and direct them on how u want it. U also might want a little piece made to get it to exit on an angle to the side, or a vertical angle, which they will have to modify ur stock exhaust to do, but can still be done for relatively cheap.
Old Apr 29, 2005
Is there any adavantages to installing it at an angle? Or just for looks? my stock bumper has a dip in it where the exhaust goes, would mounting it at an angle look bad like it wasn't supposed to be there.
Old Apr 29, 2005
Vantage's Avatar
alot of people jsut think it looks cool, but there is no advantage. u can always make it fit that stock hole too, just dont get a 5" tip thing and u should be fine, it should also be able to come out on an angle with a hole already cut,.
Old Apr 29, 2005
Yea i like it too, it has the 120mm tip on it, 80mm inlet but I'm having it sized down to 60mm.
Misfit2613
Jul 30, 2015 09:49 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
