Bought Injen Intake Need Help..
Old Mar 15, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Hey guys I just bought the injen cai intake off Vtechgrl. But it doesn't have any install manaul. Can someone tell me what I need to do to install it? I was using the AEM CAI DIY for a refference but came up on a problem. The AEM install DIY says I need to change the stock bracket of the car to the one AEM supplies. All I got from vtechgrl was the intake, no brackets. Can someone tell me if I'm missing something? Heres a pic of what I got...
Old Mar 15, 2005
skipbarber's Avatar
you have the lower pipe on upside down, that thing on the side is a bracket, it bolts to a stock airbox mounting point over the transmission.
Old Mar 16, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
well its gonna look like this from the top:
once you go the top pipe in, take the bumper off if you havent already. through the splashguard and the frame of the car you have to shimmy the lower piping through there so that it meets the other pipe. make sure the placement is correct. where both pipes meet it has to look straight and not bent when you tighten it. for that bracket near the filter, theres a wire thats screwed onto the frame, undo the screw and place the vibramount and screw the intake bracket to it, thats where the pipe is gonna hold. once you're sure of the fitment, tighten everything. place the filter on. to do all of this you might need to take the battery out to get the pipe through. hope that all made sense.
2k1civicman
Bolt-on Engine Performance
Dec 17, 2001 06:18 PM
trevor
Nov 27, 2001 01:44 PM
colombianDXcivic
Nov 25, 2001 09:38 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
InspectaDeck
Sep 22, 2001 03:18 AM
