Cold Air and Car wash
Old Feb 15, 2005
ItalianCivic77's Avatar
ItalianCivic77 is an unknown quantity at this point
Question Cold Air and Car wash
Well I went ahead and bought a CAI, and then thought of something......... You know how you cant hit puddles and whatnot so you dont submerdge the tip, well what about goin through a car wash? Is that out of the question? I normally dont neways, but in the cold season, it hurts to spend an hour cleanin it ouside!
Thanx
MIKE
Old Feb 15, 2005
turboengnr's Avatar
DONT PANIC
your only worried about deep water with a CAI. The car wash shouldnt be deep enough to cause any harm.
Old Feb 15, 2005
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
yeah, unless your forging rivers, you have nothing to worry about...
Old Feb 15, 2005
GuliziaN's Avatar
Powered by Honda...
GuliziaN will become famous soon enoughGuliziaN will become famous soon enough
^^^ Not always true... Puddles have cause drastic damage to engines depending on how much water makes it into the engine...
But regardless, you are safe in a car-wash, but you should do it yourself...
Old Feb 15, 2005
TheSmuggler's Avatar
You realize that you have to be in like 1 foot of standing water with the filter completely submerged to hydolock it permanently, most ppl kinda minorly hydrolock it and it usually dry out =) You'll be ok in the car wash =)
Old Feb 16, 2005
streetglower's Avatar
yea you are cool man. I had a Injen CAI and you could let the engine run and spray water at the bumper where the intake filter sits and be fine. I went through car washes plenty of times and was fine.
Old Feb 16, 2005
senseiturtle's Avatar
senseiturtle is an unknown quantity at this point
Just be careful... I lost an engine to hydrolock, and the puddle wasn't deep at all.
Old Feb 16, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Just avoid spraying water directly at the filter. Mist won't hurt anything.
Old Feb 16, 2005
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
and dont be at full throttle when you hit a puddle...and dont be some cool *** ricer and rev up when you're in the car wash...cuz your throttle body will open up causing more air to come in which in turn...possilby more chance of water making it in.
Old Feb 16, 2005
A small amount of water won't hurt anything. Large amounts, (greater than combustion chamber volume at TDC) will cause issues.
Old Feb 16, 2005
juzthewy's Avatar
juzthewy will become famous soon enoughjuzthewy will become famous soon enough
CAI's are a bitch but if you have the heat filter shield and the water seperator then water shouldn't be too much of a problem. Otherwise u better get ready to ur intake system out. BTW how well does the AEM CAI bypass valve work???
Old Feb 16, 2005
skillwill's Avatar
skillwill has a little shameless behaviour in the past
like **** from what I heard.
Thats kind of funny to hydrolock at the car wash
Why would your dumbass press the gas anyway when the carwash goes automatically.
Old Feb 16, 2005
actually in my own personal experience our engine can handle water with no problem. I drove through a flooded area a yr ago and drove through over 2 feet of water at 5 mph and sucked it all in my engine. I had the injen CAI at the time. My car died and wouldnt start. I thought I hydrolocked it, but I took it to a shop and they just sucked the water out of the cylinders and drained the oil and tranny fluid several times and the car ran again. The check engine came on a week later for the TPS sensor, but that was replaced and everything has been fine since. But I guess I Was lucky.
Old Feb 16, 2005
pon55's Avatar
2 feet! courage!
Gl3n1234
Apr 18, 2015 01:51 AM
ph0ng
52
Mar 4, 2003 09:15 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
SneakerPimp
Nov 4, 2001 01:12 PM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
