Breather Filter
Old Feb 9, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
Breather Filter
For anyone using an intake and having trouble connecting thse rubber hose into the breather and the intake piping let me know. I put together a new idea and it could help some of you. What I did was get a mini k&n filter and put one on each end. One on the intake piping and one on the breather itself. It seemed to make more noise and freed up some air. Now my intake has two filters while my head uses its own freeing up some air hopefully. I only spent 40$ which was alot because I could get em cheaper but this was a good brand and I havent found it anywhere else so I had to get it. If any of you members want pix let me know. The pix I took are too big to be uploaded onto this site.
Old Feb 9, 2005
im stock now! T.T
damn do I have to post up a pic to start this thread or what. give me ya'll e-mails so I can e-mail the pix to ya.
Old Feb 10, 2005
2K1Civic17"Gabe's Avatar
The hose is just too small, huh? Most of them seem that way. Just keep trying to get it on, and it should eventually go on. Lots of twisting, trying to keep it straight, and twisting, and pushing in, and keep trying. It should eventually go on.
Old Feb 10, 2005
im stock now! T.T
nope no way to go in unless you get the kn onewhich is what I have and it fits perfectly hassle free. pm for pix
Old Feb 10, 2005
im stock now! T.T
something new.........
Old Feb 11, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
why not just put a cap on the part where you put the 2nd filter for the intake, would save some cash. would too much air be bad for it? i know when i had my CAI my mileage got a little worse. post some pics of this though, i'd like to see how it looks. i'm sure other people would too, but probably to lazy to post.
[edit]just talked to my buddy, he said a breather on the head is illegal.[/edit]
Old Feb 11, 2005
im stock now! T.T
finally!!!
Old Feb 11, 2005
im stock now! T.T
Its K&N so it will get away. I did read that it was for off-road. I dont car anyways because I have got something worse than a small filter.
Old Feb 11, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
It doesn't matter if it is K&N or APC. An open filter on the crankcase does violate emissions laws and you WILL get a ticket in certain states.
Old Feb 11, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
Yep!! Failure for smog inspection in Cal, I know that!!
Old Feb 11, 2005
TeLLy's Avatar
Yes, it's an Acura EL
True, you won't get busted for the filters till after they write you the juice ticket.
Old Feb 11, 2005
im stock now! T.T
I know its not emissions legal. I have read the manual. Either way, I can remove the filter in no time and put back the rubber hose that aem supplied me with. I hear more noise now from the intake.
I dont need to get another smog inspection for another 2+years. And even if I did get a smog inspection it would be no problem because the guy will just pass me.
Old Feb 11, 2005
kornsined's Avatar
so what is the point of this? more noise? less HP?
Old Feb 11, 2005
Changu-San's Avatar
Mr. Clean
looks retarded....
Old Feb 11, 2005
c kim's Avatar
c kim is an unknown quantity at this point
If you can't get it on then just plug the hole on the intake and get a breather for the head. Getting 2 filters is kinda of a waste of $.
Old Feb 11, 2005
im stock now! T.T
I know I was going to plug it the intake hole, but with what. It was only 10$ extra so not that big of a deal. I wouldnt say I lost hp because it freed up air man. I donno what to use to plug the hole. any suggestions? btw our intake holes are way bigger than previous gen civics if you know what I mean....
Old May 18, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I put a vaccum cap on my intake and put a small K&N filter on the end of a piece of hose, looks bad ***, and now only fresh air comes in the engine and no hot air and oil vapors.
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Cam Diaz
Sep 29, 2015 07:17 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
NaturalSelectio
Sep 6, 2015 06:59 PM
