Does anyone have a DIY for Injen SRI???
i was lookin at the DIY but only for the AEM CAI with Manual Tranny, i will be getting a Injen SRI with Auto trans... can anyone help me with a DIY for an Auto??? this is my first mod...don't want to mess anything up
Once you go Black on Black, You Never Go Back.
im a 30 minutes from phily, id tell you id come up and do it for you in about 20 minutes and charge you 20 bucks for gas and lunch but i think you can handle it on your own. 2 hose clamps and a few 10mm bolts and your golden
kk thanks for the advice... so do i just leave out these steps...???
Now we will need to remove the stock transmission mounting bracket.
FIRST: Using your 27mm deep socket (PepBoys $4.99), remove the reverse light switch, and don't loose the washer.
SECOND: After removing the ground cable and clutch line bracket, remove the two 12mm bolts holding the mounting bracket onto the transmission housing.
THIRD: Install the reverse light switch. Make sure it still has the washer.
#1. take air box off
#2. place short ram on throttle body, tighten hoseclamps
#3. on the suppost for the sri, install one of the factory 10mm bolts into the screw hole
#4. congrats, your car is slower then before. but it sounds better
2k1civic.com O. G.
Holla at me. i live RIGHT IN PHILADELPHIA.
YOu may have seen my car. Blue 2001 civic EX coupe. G5 body kit, tint, exhuast, VII emblem on the back, 7thgencivic.com license plate!
aim: aznmikex215
aim: aznmikex215
injen didnt give no instructions in the box? =\ my aem sri did.
the short ram intake is a very easy install and a good expierence. its all nuts and bolts so if you can use any kind of wrench, then you can do it. i would find a local if your too worried about your work and have them watch you do it. if you make a mistake, they'll just tell you and you can learn that way.
thanks for the responses... i have much confidence... i just hope i dont pull anything out i shouldn't
and i dont want to go to a shop to do this cuase it seems basic and i'm 16 = no money
and i dont want to go to a shop to do this cuase it seems basic and i'm 16 = no money Registered!!
thats about all itll be making hehe. but all u have to pull out are the big black boxes. theres two of them, and the intake tube that runs by ur battery. make sure u have all the bolts off though, some of them might be hard to see/hard to get to.
heres what your engine bay looks like stock:
heres one with injen sri installed: minus the other fancy pieces
the photo attached are the 3 pieces of the factory airbox thats gonna be un screwed in order to bolt on the injen intake..
Heres a helpful tip...the only prob I came across was on the throttle body be sure to leave the stock gasket on there. I took mine off took me a min to realize this...after i clamped it down and it was still lose. Other then that its a breeze. Hope you dont expect much. It'll give it a nice sound after 3000rpm thats about it.
Ziggy1999
Oct 15, 2015 07:56 PM
meicalnissyen
Sep 25, 2015 12:12 AM
