D17 cam shaft?
Old Dec 24, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
D17 cam shaft?
Will the D16 cam shaft fit the D17 and has any one tried it?
Old Dec 24, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
thats an interesting question, might want to be careful testing it though since they are different displacement. not sure how much .1 L will do when chosing a camshaft but u never know.
Old Dec 24, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well it may or may not work.. since the d16 uses a distributor.. it probablly wont work on the d17
Old Dec 25, 2004
^ y would that make a difference? timing wouldnt really be different or anything.
Old Dec 25, 2004
18inchpride's Avatar
18inchpride is an unknown quantity at this point
wouldn't it make a difference on the timing of your valves! depending on if your vtec head as well! as for timing, i would see there being a difference using a D16 cam! but then again i may be wrong?
Old Dec 25, 2004
WannaBFast's Avatar
no, but there is a gear for the distributor..
Old Dec 25, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
I could forsee the gear playing a role, but if you're taking the cam from a d16 into a d17, the gear shouldn't make any difference (take for example RWD ka24de in 240sx's...they are RWD so the dist doens't run off the cam, like it does in the Altima..however you can take altima cams and run them in the RWD engine..)
Old Dec 25, 2004
well yeah i know theres a gear for it, but as long as its not hitting anything it wouldnt really matter. it could spin there all it wants.
Old Dec 25, 2004
AceAltima's Avatar
Exactly...didn't anyone read my post???
Old Dec 25, 2004
yeah, im just elaborating on it.
Old Dec 26, 2004
freeturkeys's Avatar
freeturkeys is an unknown quantity at this point
anything is possible
Old Nov 21, 2017
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
Re: D17 cam shaft?
I have this same question. Did you ever try it?
Old Nov 23, 2017
Re: D17 cam shaft?
Huh, last post was 13 years ago...
ricer_em2
May 11, 2016 08:09 PM
speedlever
Sep 24, 2015 07:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
