HKS Axelback and Apexi GT spec midpipe
Old Dec 16, 2004
R3DL1N3's Avatar
would the hks rear section axel back fit right with an apexi gt spec midpipe? i was debating buying one if it would fit right. im sure it would be a little bit quieter than my gt spec muffler.
Old Dec 16, 2004
sw388integra's Avatar
it might be quiter...with the silencer in it...
Old Dec 16, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
I don't know if the pipes will match up, but I did find this:
http://www.optauto.com/index.htm?dep...itemsperpage=9
It might help with the sound issue, but from what I have heard the HKS exhaust is pretty loud on its own...
Old Dec 16, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
Do you already have a cat-back? If so, you should go to your local auto part store and buy a cherry bomb and have it welded in. My buddy did this and it got a lot quieter. He didnt have a cat so when he did this, he had flanges welded in so that when emissions comes around he can take out the cherry bomb and bolt up a cat converter. Its that simple......very inexpensive and works great.
Old Dec 16, 2004
import2nr's Avatar
awd pwnz j00
it would probably work if the flanges are the same where they meet.
also can you post up some good pics of the gt spec on your car. i havent seen it on a 7thgne and i would like to
Old Dec 16, 2004
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
No I have the hks and I believe its one of the quietest axhaust out for our cars, unless you have a cat delete pipe, then It can be very loud so I have heard, but just the axleback is quiet.
Old Dec 16, 2004
03HondaEx's Avatar
I stand corrected...
Old Dec 16, 2004
MrDibbs19's Avatar
MrDibbs19 is an unknown quantity at this point
aren't cherry bombs really loud??? i thought they were...
Old Dec 16, 2004
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
The Hks piping is a little less then 2 inches like 1.8" i think... the GT pipe i expect is like 60 mm. 2.54cm = 1 inch so the GT pipe is like 2.3 inches.... So there is a about a half inch difference in piping diameter. Something to think about...
Old Dec 17, 2004
SIinthesky's Avatar
If you are only using a cherry bomb it is loud. When you have a cherry bomb in the middle and another muffler out back it makes it pretty quite. Its not going to be silent or anything. But it will be quite. I flowed a cherrybomb on a flow bench and it flowed about 100% which means it will not hurt performance at all.
Old Dec 17, 2004
R1Style's Avatar
I don't know if that's right. The flange opening might be that small so it'll mate with the OEM exhaust but from there, the piping get's larger.
Old Dec 17, 2004
scansel912's Avatar
Nah dude I'm 100% sure that the piping on the HKS is a little less than 2 inches. I have it off my car right now and I measured the circumference of the pipe with paper strip on the outside. Then I made a circle with the paper and measured the diameter and it was exactly 2 inches give or take a little bit. Thats the Outside diameter of the pipe and not the inside. Therefore the inside has to be less then 2 inches. Kinda sucks doesnt it...
Tedverseti
Apr 23, 2020 01:45 PM
Elciteeve
Sep 28, 2015 12:40 PM
fvckbg
Sep 8, 2015 09:55 PM
thaler4cuse
Sep 7, 2015 08:25 PM
cukaracha
Aug 27, 2015 02:02 AM
