Cone filter cleaning report
Old Sep 10, 2004
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
Hey all...
Recently, I decided it was time to check my AEM CAI's cone filter and was shocked at the amount of crap that was stuck to it. One side was literally caked with mud/grease and the whole thing was pure dirt and grime.
I had wondered what the hell happened to my MPG!
So, I priced new filters since it was kinda banged up and was shocked to find that the replacement runs $75-100 USD. Then on another board I was told to just go get a cleaner kit.
Found one from K&N from PepBoys for $11 USD and last Saturday while washing/waxing I cleaned it. Very easy to use, just spray on the cleaner, let sit, rinse, repeat until clean. I did three passes and then hosed it off real nice. ONce it's air dried, you spray on the red oil to coat the filter, let it sit till its all soaked in and reinstall.
Made a definate difference in my MPG, even when AC is running and makes me feel happy to have saved my dum *** $90 instead of having bought a new one.
How often do you guys clean yours? I assume in AZ etc where its extra dusty youd do it more?
Old Sep 10, 2004
streetglower's Avatar
I cleaned it once and then bought a new one. Even after I cleaned it, there was still freakin dirt and what not caked in the filter, so I just bought a new one. I paid $35 shipped for my filter.
Old Sep 10, 2004
Was it a brand name or a generic? Has it worked well?
I had to bang the crap out of mine on the ground to get the larger stuff off, and hosed it pretty well to rinse out the rest after I degreased and soaked it several times.
I am sure there will occassionally be some seriously stubborn crud in there that just won't come out without damaging the filter itself.
Old Sep 10, 2004
Ok, sorry, it was $37 shipped. only $2 more. But it was a injen filter. For my injen CAI. And yes, since I put the new one on, I have gotten about 50 more miles out of my tank then I did before, and my car has better pickup now, and doesnt lag.
Old Sep 10, 2004
great price for the filter! i assume it would probably work on any SRI/CAI as long as the diamter of the tube was the same.
Old Sep 10, 2004
just find out what diameter filter you use, and you can pretty much use any other one. But some intake manufactures only recommend using there filter because it was designed for the intake. And using other ones cause the intake to not becdome CARB legal and what not.
Old Sep 10, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
I check my CAI filter everytime I change my oil. I havent had to clean it yet. Mine stays pretty clean.
Old Sep 13, 2004
I think mine got most of it's dirtyness from the water I've driven thru here. I def should have checked it sooner!
Old Sep 13, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I use the Apexi cone filter now. Easier to clean and flow and filters much better.
Old Sep 13, 2004
taz757's Avatar
Where can I get it at? I think the filter on the AEM SRI is 2.75" diameter.
Old Sep 13, 2004
gusgus0513's Avatar
gusgus0513 is an unknown quantity at this point
i would clean once every 3-4 months always wash from the inside out
Old Sep 13, 2004
bobbyd's Avatar
I got mine from my local performance shop. Here is a list of their dealers: http://www.apexi-usa.com/dealers.asp
Old Sep 13, 2004
taz757's Avatar
Damn. No dealers here in VA.
Old Sep 13, 2004
djmota's Avatar
I clean mine every other oil change. Aem uses a K&N filter. You should not have to replace it unless you mess it up some how.
Old Sep 13, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Last time I cleaned it (2 weeks ago), there was dirt on the outside, and a little bit inside. I cleaned it, still there on the outside.... so I'm going with gearbox, and getting myself an S&B filter in a month or 2. btw, prior to my last cleaning, I cleaned it.... I think in May
Old Sep 13, 2004
zachgeyer's Avatar
never
Old Sep 13, 2004
K&N recommends cleaning around every 50k miles because the filter works like crap when new. I'm ordering a new S&B filter for my fipk. The apexi one is also excellent if you get it to fit.
97-DX-Lover
Jun 14, 2015 06:07 PM
carid
Apr 30, 2015 07:00 AM
vistec
Feb 13, 2002 08:09 PM
supsoop
Feb 10, 2002 09:38 PM
