qusetion bout a DIY CAI
Old Feb 10, 2002
supsoop's Avatar
supsoop is an unknown quantity at this point
can i just take out my resonator and air filter then hook up a pipe to the hole in the air box where the resonator was hooked up too then put a cone filter at the end of my pipe?? cause i dont wanna mess with drilling a hole in the pipe for the sensor and finding a way to hook up the breather hose. any suggestions?? will my plan work?
Old Feb 10, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
the filter is not in the resonator, it's in the other box. that sounded like a good idea at first but you're gonna have to do the whole thing. i'm still workin on my DIY as well. i'm doing a variation of the DIY at jdmfan.com. i'm using the same pipes he used.
EDIT: having re-read what you posted, i guess you could do that. you'll get better flow if you replaced the whole thing
Old Feb 10, 2002
supsoop's Avatar
i know the filter is in the air box. theres nothing in the resonator.
Old Feb 10, 2002
01civicboi's Avatar
your idea should work. you'll get better airflow if you use a single pipe though
Old Feb 10, 2002
supsoop's Avatar
oh one more thing, does anyone know where i can get a pipe for cheap. i found one but its galvanized will that work??
Old Feb 10, 2002
01civicboi's Avatar
i got mine from JCWhitney . part# 81EH3035N
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
henrytn
Aug 11, 2015 10:01 PM
