Aem Short Ram Intake
Old Jul 12, 2004
  #31
sasquatch's Avatar
sasquatch is an unknown quantity at this point
I just installed the AEM SRI on my 01 EX A/T. It was an easy install. There is no difference in the sound unless you punch it. I noticed no drop in lower rpms at all. FWIW, on Aempower.com they have published dynos of different civics with different products. For example, for my car the SRI actually provided my hp and torque over a wider range then with the V2. It was a very easy install.
Old Jul 13, 2004
  #32
antok86's Avatar
antok86 is an unknown quantity at this point
Originally Posted by se7engen_riDe
Get The Red Aem Sri
Very Prettyyyy!!!
haha i plan TO!!!! get the RED ONE!!! ahhaa
Old Jul 13, 2004
  #33
antok86's Avatar
Talking
how many RPMs...till u notice the sound...people been sayin 3000...but wat do you notice yours at?..3000 RPMS...is the 3 right??? just makin sure...
Old Jul 13, 2004
  #34
sasquatch's Avatar
yeah, about 3k is right....again it depends on the demand for air/fuel you're making. If I'm casually cruising on the freeway at 3k rpm, it'll sound normal, if I dip into the throttle right around 3k you hear the change.....sounds cool too (not ricey)
Old Jul 13, 2004
  #35
antok86's Avatar
sweet....have fun!! =)
Old Jul 13, 2004
  #36
antok86's Avatar
sasquatch!! did u reset your ECU?? or wat? did u let it learn on its own??
Old Jul 14, 2004
  #37
zachgeyer's Avatar
self
Old Jul 14, 2004
  #38
sasquatch's Avatar
I reset my ECU...I had my battery disconnected during the install just to be safe anyway....I pulled the ECU fuse (there is only one) for about 10 min while I cleaned up, started the car w/o touching the gas and let it run for 10 min. I turned the car off then turned it back on (again w/o touching the gas). No check engine lights came on so I guess I did it right. You'll need your radio code though.
Old Jul 14, 2004
  #39
dannn's Avatar
unique conformist
dannn will become famous soon enough
Originally Posted by pon55
I have the cheap,generic E-bay special! And it works great.(after a few minor mods)
wat type of mods did you do.
i was thinking of buying one of those and messing around with it.
Old Jul 14, 2004
  #40
antok86's Avatar
how about i let it learn on its own..and not touch ECU or unplug battery...is it safe this way also??? will it affect my engine?? like harm it in neway....or is resetting just a faster way...instead of learning on its own?? thanks
Old Jul 14, 2004
  #41
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
If you want to feel the difference (or not) faster then disconnect.
Old Jul 14, 2004
  #42
antok86's Avatar
ok i noticed that injen has heat shields so waht are they for?? and why doesnt AEM have one?? Is there any heat shields that will fit AEM-22-503 short ram intake?
Old Jul 16, 2004
  #43
antok86's Avatar
bump
Old Jul 16, 2004
  #44
antok86's Avatar
ok if i disconnect the battery b4 i begin..and work...then when im finished i hook the battery back up....how long to i IDLE?
Old Jul 16, 2004
  #45
sasquatch's Avatar
let it idle 10 min (no throttle), turn it off. Then turn it back on again (no need to let it idle a long time again, still no throttle), turn it off...............turn it back on and go check it out.
Old Jul 17, 2004
  #46
antok86's Avatar
k great...thanks
Old Aug 17, 2004
  #47
UltimateWarrior's Avatar
Pimp My Ride!! Please!
UltimateWarrior is an unknown quantity at this point
Stop,look,and listen! A newbie needs to spend the time to learn. It's easy, I did it!!
Read the DIY's and all info you can find. You can do it!
I got one of those too. What mods did you make?
Why spend over $100 when you can get one of Ebay for $30, shipping and all. I mean, they all kinda do the same thing....just make noise. As far as performance, I agree... leave the stock intake on. If you like noise, just buy a cheap one until you change your mind. If you get tired of the short ram, or if you notice it making your car perform worse you are not out much that way.
Don't waste your money folks. Sure, the Ebay one might not look as nice because it doesn't come with a colored pipe but if all you are wanting is sound it's a good deal. Thanks to Gearbox for enlightening me!
Have fun!
Old Aug 17, 2004
  #48
Opps, that's the thread I meant to quote... Sorry!
Old Aug 17, 2004
  #49
antok86's Avatar
cuz u get waht u pay for....
carid
Nov 7, 2015 01:46 AM
Farticle69
Aug 6, 2015 08:02 PM
spyder13
Jul 31, 2015 06:31 PM
Misfit2613
Jul 30, 2015 09:49 AM
Theshwartz35
Jul 17, 2015 11:13 PM
