Fuel Cooler
Old Apr 28, 2004
Kore's Avatar
Kore is an unknown quantity at this point
Fuel Cooler
Does anyone have a fuel cooler installled in their car? It's a small container that has extra piping rolled like a coil within the can that's install in the engine bay before the fuel hits the fuel rail. You add ice and water in the can and it cools the fuel before it reaches the combusion chamber.... you can find these at JEGS.
I just want to see if it's well worth the $$$ of if i should make my own =)
Old Apr 28, 2004
TMRakip's Avatar
TMRakip is an unknown quantity at this point
Sounds kinda scandalous to me...kinda like a 'cold air' intake...
Old Apr 29, 2004
cdmx's Avatar
wtf? ive never heard of that...what would be the point..
someone explain
Old Apr 29, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
someone explain
It would be worthless to even use probably. I can see it's benefit on a high compression, or forced induction motor, but not on a I/H/E car. If it were possible to cool the fuel enough, it would be able to lower cylinder temperatures. I'm sure full out race motors, and hi boost TC or SC cars would benefit from it at least somewhat to prevent detonation, and cars that need larger fuel pumps, are subject to higher fuel temperatures, but depends on the actual location and lph of the pump, how the lines are run, and at what pressure. In those cases it's more about whether the fuel is in danger of reaching a temperature high enough to cause a vapor lock. But it wouldn't help a stock car.
Old Jul 21, 2004
Kore's Avatar
Just got one off eBay, going to see if i notice any gains.... $50 bucks its worth a shot...
Old Jul 21, 2004
Skellz's Avatar
Skellz is an unknown quantity at this point
My friend has is on his Impala - He likes it but honestly if it over $20 - forgetaboutit
carid
Nov 7, 2015 01:46 AM
cwisenbaker06
Aug 19, 2015 04:29 PM
adamdrives
15
Aug 8, 2015 08:53 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
