Intakes
Old Mar 24, 2004
blu03civic's Avatar
blu03civic is an unknown quantity at this point
Intakes
Im sure this has been covered before, but I searched and its almost impossible to find what i'm looking for because the subject is so broad, but what is the difference between Short Ram Intake and Cold Air Intake? Thanks for any help.
Old Mar 24, 2004
MagMetal04
Guest
Posts: n/a
Short ram is under the hood and stops there. Cold air is longer and weaves all the way down to the front of the car.
Old Mar 24, 2004
MagMetal04
Guest
Posts: n/a
Short ram
Cold air
Old Mar 24, 2004
blu03civic's Avatar
So thats basically the only difference? Nothing different by how they perform?
Old Mar 24, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
well for my exp, SRI is better for me, and as for CAI it seem as i just lose some hp, maybe thats me,
Old Mar 24, 2004
Mr.Modify's Avatar
CAI= Cold Air Flowing through= Better Performance Wise.
SRI=Better than stock. More Air Flow. But Hotter Air Flowing Through(not so good)
So performance wise go with CAI beware though don't go through any deep puddles or hydrolock will occur.
Old Mar 25, 2004
goodtimes's Avatar
this may be stupied but what is hydrolock, let me know thanks
Old Mar 25, 2004
K20me's Avatar
hydrolock is when water is sucked into your engine preferrably by a CAI...this water will cause your engine to stall and just die...i wouldn't know from experience though...
Old Mar 25, 2004
goodtimes's Avatar
thanks
Old Mar 25, 2004
cambo's Avatar
I wish I was asian
a CAI usually yields more horsepower gain than a SRI, but at the sacrifice of lower end power.
this is discussed in the FAQ of the site, you might want to check it out. Its on the menu on the left side of the page.
Old Mar 25, 2004
highrollerbjm's Avatar
highrollerbjm is an unknown quantity at this point
You can get a heat shield for Short Ram intakes that really seem to help prevent some of the hot air....kinda like on the FIPK2 intake youll hear about.... get it
Old Mar 25, 2004
AutoK20A3's Avatar
AutoK20A3 is an unknown quantity at this point
Nice to see there is no, "Search, n00b!" on this thread so far! Good job guys! Way to help, even though this is a newbie question. We were all there once.
Old Mar 25, 2004
Eeeeeeh's Avatar
Eeeeeeh is an unknown quantity at this point
Cold Air Intakes do may sacrifice low end power (From taking off the cold air extension and making my intake system into a short ram I couldn't hardly tell a difference) but you are going to want to focus on top end power if you want to be racing.
Old Mar 25, 2004
cryption's Avatar
2003 Nissan Frontier
if you get a bypass valve on a CAI you really reduce the risk of hydrolocking ... I've been owned by some puddles and never hydrolocked
Old Mar 25, 2004
SilverVSpec02's Avatar
SilverVSpec02 is an unknown quantity at this point
^ he has. i've been with them. i running my CAI w/o a bypass valva right now and have not noticed any problems yet, but i refuse to drive during heavy rain, or through large puddles. on my spec-v i have noticed miniscule gains in the higher rpms due to the hotter climate in texas, but i did notice a loss in lower end torque.
Old Mar 25, 2004
Eeeeeeh's Avatar
I drive in the rain with my CAI, but I don't mash down on the gas. I don't think having a cold air without a bypass valve should scare people from driving in the rain, just be very light on the pedal.
Old Mar 25, 2004
blu03civic's Avatar
So which should i get? Or does it really matter considering our car doesn't gain much with small modifications.
Old Mar 25, 2004
zachgeyer's Avatar
Aem works nice
Old Mar 25, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
I have the injen short ram and a aem cold air intakes.
I tend to stay with the aem cold air during the summer time and only use the short ram during winter. Injen short ram is a lot louder than the aem cold air. Performance wise, I would say the aem is a better buy.
Jeff
Old Mar 26, 2004
blu03civic's Avatar
Aight thanks. I was gonna go AEM either way.
Old Mar 31, 2004
IronFist's Avatar
Cold Air Intakes - get colder air, which is more dense than warmer air, and therefore has more oxygen which means better performance. Unfortunately, all the bends and long piping can slow the air down. Cold air intakes also are succeptable to hydrolock.
Short Ram Intakes - get warmer air cuz they stay closer to the engine. But the air moves faster so you get more of it.
Metal intakes get very hot to the touch after a few minutes of the engine running. Most intakes are metal.
K&N makes a short intake with a heat shield to minimize warm air going in, and it's also plastic, so it doesn't heat up. After long trips it will still be cool to the touch. It's called K&N FIPK II.
UltraHDGames
Jun 8, 2016 05:16 PM
ThatGuy913
Nov 9, 2015 06:31 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
