Well, my Injen is F-ed...
Old Mar 13, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
This is the semi-nasty e-mail I just sent them...
Hi, please click the 2 linked photos I am enclosing of the piping that has been installed in my 2002 Civic EX for about a year now. One of the pictures shows the result of the battery shroud (which is plastic) rubbing on the intake pipe, and the other shows the result of the lower frame rail rubbing on the pipe (it also ate through the rubber pad supplied with the kit). I was under the impression you guys had these kinds of fitment issues worked out, any comment regarding these? I've seen this before on 2001+ Civics, so I know I'm not alone, I'm beginning to wonder if something isn't right. I'm glad I caught it before the frame rail ate a hole in the pipe behind the filter.
Please let me know if you have a solution to this issue, $200 is a lot of money to waste on a part if 1 year is all its going to last.
I'm interested in seeing what they say. I'm under the assumption thats not supposed to happen, and given the fact that it only installs 1 way, the bends in the piping determine its orientation in the engine bay. Anyways, I await their reply, in the meantime, the stock box is going back in... and hopefully they'll replace that pipe, cuz I'm not putting that back in the car.
Old Mar 13, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
is that a sri or cai?
Old Mar 13, 2004
RedDragon333's Avatar
CAI
Old Mar 13, 2004
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
holy sh*t the pipe in the 2nd pic has some nasty damage
Old Mar 13, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
damn that is some shitty job there.
Old Mar 13, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
well have they replied to you yet?
Injen
Old Mar 13, 2004
Jap-Euro Fusion
Ummm its saturday. If I just wrote today, I'm thinkin it'll be Monday at the earliest.
In the mean time, I'm working on finding a way to canabalize the top pipe and the filter into a cold air box similar to the Icebox.
Old Mar 13, 2004
injencivic's Avatar
oh i didnt know you sent it today
my intake doesnt have anything like that
Injen
Old Mar 13, 2004
7thGenerasianCivic's Avatar
damn... that is really bad man! Good luck with them.
Old Mar 13, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
i am not trying to say that it is your fault....but dont you think that they will tell you that it is due to improper installation....do you think that you could have done something to prevent it....hold the pipes in place and make sure that they had clearance from everything and then tighten stuff down...i am not trying to make you sound stupid, or that it is your fault..i am just askin if you think that it could have been prevented, or was there just not enough clearance for it all the way around
Old Mar 13, 2004
RiceBuRNeR's Avatar
Turbo Member
that happened to one of my charge pipes. I just slipped silicone coupler over the hole and clamped it down.
Old Mar 13, 2004
Jap-Euro Fusion
The way the bracketing is designed... it only goes in at 1 angle. That lower pipe is only held in place with 1 bolt and its up top, near the joint that connects the 2 pipes. I think they're actually relying on the frame rail to hold the pipe in place, because other than that, its free to move and vibrate. There's really not enough room down there, you need to cut the splash guard a little to get it to fit in, and you need to trim the battery tray. They tell you this, I did both. No avail. What they need is another bracket down low somewhere to lock it in place so it CANNOT move at all.
Old Mar 13, 2004
Zzyzx's Avatar
Autocross Junky
Boilermaker, From talking to a couple of ex CSP guys (88 CRX si) they said that the car performed better with the stock box on minus the resonator. Vs short rams or cold air intakes.... Maybe your better off.
Old Mar 13, 2004
silverem2's Avatar
this seems much different from the aem cai the way you explain, with my aem cai, it doesnt touch anything
Old Mar 13, 2004
Jap-Euro Fusion
I just took the car out to my "fun road". The bottom end came back, the top end is gone. So I guess I can no longer say the intake did nothing. I'll tinker around with it, see if I can find a nearly stock-type setup. Obviously having some kind of box rather than an open ended filter plays to the low end, but it does feel like the car is getting a little choked up above 6K. I'm thinking I can cut up the Injen piping and either build a new box to surround the cone filter I have, or get an Integra or EM1 Si airbox and modify that to fit in the car where the resonator sits. Time for ol' Boiler to get creative...
Anyone know what type of plastic the air box is made out of? Somekind of nylon or something?
Old Mar 13, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
holy ****....u got 1 hard *** plastic material in ur car.
according to science scratch resistence number of plastic is lower then the metal.....i dont see how that can happen.
but yea...that sux man....luckily u caught....dont want dirt in ur engine....hope u they send u a new one
Old Mar 14, 2004
EnProceso's Avatar
weird, i've had mine for about a year and just today i was polishing it and didnt notice anything like that...
Old Mar 14, 2004
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
dang man that sucks about your whole issue with injen, but i kinda like your idea of a custom intake/air box.
Old Mar 15, 2004
Krepoort's Avatar
Krepoort is an unknown quantity at this point
I cant see the pics for some reason, but I hope they will replace it for free. Good luck.
-Kre
Old Mar 15, 2004
Jap-Euro Fusion
Well, honestly, I don't care if they replace it. Its just gonna happen again. So rather than keep calling them every year (they're probably going to be pains in the asses about it anyways because they'll be little bitches and not stand behind what they make, I've already mocked-up, test fitted and blueprinted a new airbox. Polycarbonate sheeting is on the way, so when it gets here tomorrow, I'm starting on my own intake system. In theory it should work better since the filter will be in a resonator box, protected from the elements and most importantly, completely eliminating the possiblilty of hydrolock (I was never superworried, but extra insurance is good).
Old Mar 15, 2004
Titleist71's Avatar
my rubber connector to the throttle body is brownish...may b rust...from clamp.
Old Mar 15, 2004
HondaLuver's Avatar
Its a celebration bitches!
looks like ur going to have to change ur name
Old Mar 15, 2004
MONTREALCIVIC's Avatar
MONTREALCIVIC is an unknown quantity at this point
aem all the way.
that should not have happend
Old Mar 15, 2004
Jap-Euro Fusion
Change it to what?
Old Mar 16, 2004
goodtimes's Avatar
dam thats sucks man i have an injen cai and i wonder if thats going to happen to mine.
Old Mar 16, 2004
HondaLuver's Avatar
change to "stock owns me"
Old Mar 16, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
Hmmm...yeah...I'm finding that I need to be at about 4k to get any kind of power out of my AEM CAI...so if you find a good way to mod yours with a box...I'd be interested in knowing how you did it...(read WE NEED DIY!!).
I'm tired of down shifting to 1st only to redline it, hit the limiter, cuss at myself/car while coming out of a turn, and upshift as soon as possible, lol. Funny thing is...even though I do all that...I STILL run faster than if I stay in 2nd most of the time...lol. So yeah...I'd LOVE some more low-end!!!
Old Mar 16, 2004
01civicUP's Avatar
01civicUP is an unknown quantity at this point
ya man ive had nothing but back things to say about the INJEN cai. the **** hits my hood, rubbed threw on the lower part by my filter from hitting against the frame. I dont understand why they didnt do a better job researching this before releasing it.
Old Mar 16, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Boilermaker, mine did the same thing. Drove me nuts, for awhile it was rattling where it fits through the opening at the bottom. I fixed the problem temporarily by wrapping the pipe in duct tape... then when it ate through that, I sold it and bought the (at the time) recently released K&N FIPK. That was a great intake, never gave me any problems. Still glad I got rid of it though, having a less annoying sounding car has been nice.
Old Mar 23, 2004
FattyMcJ's Avatar
So...any news?
Did you figure something out?
Can't keep us waiting man!! lol
