tranny swap
x-factor
tranny swap
so chenz blew his car and is selling me the tranny for cheap!!!!!!!!!!!!! heres what im getting:
tranny
ecu
linkage
axles
flywheel
i know i will need:
the hydrolic assemply
pedals
shifter
what else would i need?
tranny
ecu
linkage
axles
flywheel
i know i will need:
pedals
shifter
x-factor
im not getting a k20.......he is
edit: ok so i gotta price of 900 for the swap all i gotta do is get all the stuff takes 4 days to do....im so gonna do this if chenz can come thru what else do i need people!!!!!!!!!!!!!!
Unless you're wrapping this into something else...
Clutch
Pressure plate
throw out bearing
and the clutch pedal lock out for the ignition... I don't think the ECU will start the car without it, unless you can bypass it somehow...
have fun
Clutch
Pressure plate
throw out bearing
have fun
Clutch
Pressure plate
throw out bearing
have fun
Clutch
Pressure plate
throw out bearing
have fun
and he'll have my ECU... lol alex and you guys really need to start reading posts in our mid atlantic forum ....
but yeah i blew my motor... full story is here..
http://www.7thgencivic.com/forums/sh...5&pagenumber=1
uhm the lx ex thing shouldnt be a problem.. tranny is a tranny.. he's just going to need a EX manual ECU
You will need the entire transmission (supplied by chenz), and an EX manual ECU (you cant use Chenz's because he doesn't have vtec) not to mention all the pedals and shifter, hydrolics, cables, etc. You might want to also look into gear ratios. I know a tranny is a tranny, but i don't think it is worth
are you sure you need an ecu? oh one thing I know if you change your tranny you need to get the ecu flashed at honda for your key they said they charge 50 bucks.I really dont want to change the ecu and all that crap. Oh btw would it matter if I got a 4dr civic sedan 2001 ex ecu 5speed? I have a 2002 2dr civic coupe ex. Thanks.
I have everything for this swap and costs me around 1650 with install.
there is a lot of other crap you have to get master cylinder, shift linkage, shifter assembly, pedal assembly, clutch, flywheel, pressure plate. The wiring harness alone costs $200. I am going turbo so I got the 6 puck clutch and the 11 lbs flywheel and xtreme pressure plate.
some guy also told me that your foot will be soar because the clutch has no springs in it, and is really hard.
oh well I guess its all worth it. I would have lost more money trading in my car because of my miles and I crashed it and I have modded up my car also.
oh well I guess its all worth it. I would have lost more money trading in my car because of my miles and I crashed it and I have modded up my car also. Last edited by Elite; Oct 16, 2003 at 02:05 AM.
May 4, 2016 07:14 AM
2005seTO
Aug 18, 2015 12:45 PM
