can't decide on which
Old Jul 29, 2003
movfyw's Avatar
movfyw is an unknown quantity at this point
Question can't decide on which
i've got a 02 coupe ex auto. mods are: aem sri, dc headers unorthodox pulley set i've searched for both i want to get eithe rthe venom 400 or send my ecu to jet. i can't decide which to do i've read good things and bad things for both and also wondering if i went with jet could i hook up the venom 400 also or would that not be possible. so need some input on what i should do
Old Jul 29, 2003
horatio's Avatar
horatio is an unknown quantity at this point
what do u plan on adding in the future?
Old Jul 29, 2003
civicdude's Avatar
This belongs in parts, I am moving it there
Old Jul 29, 2003
pheaton's Avatar
A descendant of 2k1civic.com
Umm. . I think that you should go Venom. . The jet mod should be the last thing that you do. . If you do the jet now, then you'll loose that investment later if you wanna do the Venom. So just do the Venom for now. . It's more bang for your buck too.
Old Jul 29, 2003
dezod's Avatar
7thgen Power Maker
jet should be the last thing done.....go jet w/ v-afc II......your $ then!
Old Jul 29, 2003
RedDragon333's Avatar
i would go for Venom if you want results now, the Jet works with ALL the mods done so it should be the last mod done to the engine to get the best results
Old Jul 29, 2003
IronFist's Avatar
I was going to say the opposite of everyone else, because I don't know if the Venom actually adds any hp or not.
But if you're going to add more, then don't get the Jet chip just yet.
IronFist
Old Jul 29, 2003
IronFist's Avatar
What did you notice from the Unorthodox pullies?
IronFist
Old Jul 29, 2003
movfyw's Avatar
so for the wrong forum i plan to add a high flow cat, exhaust, and a torque converter later so yeah i'll probably go with the venom. so does that mean i can use the venom with the jet ecu
good low toque gains with the pulleys but i would of just got the crank 'cause the alt. and p.s. pulleys weighed the same but i didn't measure the diameter of the pulleys so that might be different
Old Jul 29, 2003
horatio's Avatar
IronFist
i agree kinda, jet is proven power, just give them the specs for your current mods and future mods or else you will be spending a lot of cash on reprograming.
Old Jul 29, 2003
movfyw's Avatar
so just don't get thevenom is that what your saying horatio but nobody's answering if you can use the venom with the jet ecu is that possible
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
charmon4815
General
Sep 22, 2015 08:00 AM
TheRiddicles
Sep 21, 2015 03:34 PM
