philips silvervision cornering bulbs
For our cars, they only make one size and that is 7440. If you are lucky enough to have jdm taillights for your sedan, these are the perfect bulb for you. They also work nicely in the front turn signal of 01-03 clear headlights, however you will lose the parking light function.
Pros: this is hands down the BEST chrome coated amber bulb you can ever find, anywhere. It is actually almost 2x brighter than a standard orange coated bulb (hard to believe but true), and looks 90% invisible in clear reflector housings. The lit amber color is a nearly exact match for LED amber colors, rather than the darker orange from normal amber bulbs.
Cons: the bulbs didnt fit in the socket, not even close. I had to bust out the dremel and shave 8 lil glass 'nubs' from the bulb base before it finally clicked in the socket. maybe its a usdm/jdm socket problem, but they can be made to fit. Also, these would not last very long if used as a drl because the coating would trap too much heat inside.
pic in the corner/turn signal reflector
Re: philips silvervision cornering bulbs
those are the depo led tails i got on ebay for $180 but now they are going for 150 which is a steal. they are a ton brighter than stock.
another pic with silvervision signals
dlg1985
Jul 23, 2017 10:03 PM
cferry7
Oct 18, 2015 06:32 PM
Sep 27, 2015 11:33 AM
Touge
Sep 23, 2015 10:51 PM
MamaBear2015
Sep 4, 2015 09:04 PM
