HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
HID 2009 Civic
Old Dec 1, 2015
ZoSoIV's Avatar
ZoSoIV is an unknown quantity at this point
HID 2009 Civic
Ok I've seen a few YouTube videos on doing HID on a 2009 Civic just wanted some info from the doers here if it's a pain to get to the bulbs or not , I don't want to take the front bumper off
Old Dec 1, 2015
Re: HID 2009 Civic
Stock headlight bulbs are usually fairly easy to change, either you can reach them from above in the engine compartment or you pull the inner fender liner down a bit and reach in through the wheelwell to get to the back of the headlight housing.
If you want to remove the entire headlight housings, you need to pull the bumper cover off.
Stock headlight housings are not suited for HID use. The beam pattern will be crap and you may blind other drivers.
Finally.....
When you install and find places to hide the components.....
DO NOT MOUNT A BALLAST ANYWHERE NEAR THE ABS UNIT OR ITS WIRING HARNESS!!!!!!!!!
You can thank me for that bit of advice later.
HTH
Old Dec 1, 2015
ZoSoIV's Avatar
Re: HID 2009 Civic
Yeah I knew about the abs unit , how about LEDs easier no ballast right?
Old Dec 1, 2015
Re: HID 2009 Civic
I dunno, I've got stock headlights in my car.
I've been strongly considering HIR bulbs for mine, but haven't done it yet.
Old Dec 1, 2015
ZoSoIV's Avatar
Re: HID 2009 Civic
HID you mean , I've read the HID are fine in the Civic headlight housing without going projectors
Old Dec 1, 2015
Re: HID 2009 Civic
No, I mean HIR. Halogen Infrared Reflecting
http://www.finemotoring.com/
Old Dec 10, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: HID 2009 Civic
If by fine you mean illegal then yes they are good at that. Even projector retrofits are illegal, but at least they have a proper beam pattern and actually put usable light down the road and not scatter it everywhere.
And please keep your bulb color below 6K if you do go hid. Blue light hurts both the drivers and the oncoming traffics ability to see. The eye can't process it the same as white/yellow light wavelengths.
Old Dec 11, 2015
Re: HID 2009 Civic
Don't put HIDs in stock reflector headlights. Retrofitting HID projectors into 8thgen headlights isn't hard. Less chance of getting pulled over for em. And as far as color temp goes, 4500-5000k is all you should be going. Even 6000k is too blue
fatih717171
Jul 25, 2016 06:22 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Daniel420
Jan 1, 2002 07:19 PM
eXNBP
Nov 20, 2001 02:48 PM
se7en
Nov 12, 2001 10:13 AM
