West Alaska, Arizona, Colorado, Hawaii, Idaho, Montana, Nevada, New Mexico, Oregon, Utah, Washington, Wyoming
shifter squeaking
Old Nov 13, 2010
Civic_Racer13's Avatar
Civic_Racer13 is an unknown quantity at this point
shifter squeaking
Hi All,
I am having an issue with my 01 civic hx. the shifter and or clutch pedal squeaks whenever I try to shift and sometimes it is hard to shift. Does anyone have any idea on what my issue could be and how to solve it?
Old Nov 13, 2010
Mad Dog Tannen's Avatar
Re: shifter squeaking
Could be the cables or connectors, at the tranny or the shifter. I would lube them up and see of that fixes it.
Old Nov 13, 2010
Do you know where I could find instructions on how to open up my center console so I can do this repair as I have never torn apart my interior before and would like not to mess it up. Also where are the spot to lube up to stop the squeaking and what do I use?
Old Nov 13, 2010
Most cars it just has clips that hold it in. There might be a couple of screws. Look underneath the cup holders and stuff and you might find em
Old Nov 13, 2010
Once I have the center console off, what parts/areas do I lube up and what is the product for this sort of job? Would WD40 work?
Old Nov 13, 2010
WD-40 is too light. I would maybe use WD-40 tp get down in the cable but I would use grease everywhere else. I would not use white lithium grease though.
Grease anything that moves!
Old Nov 13, 2010
Why would you not use white lithium grease for this sort of job? and what grease would you use instead?
Old Nov 13, 2010
WLG kinda dries out and is too thin. I tried it back in the day on my dirt bikes and the stuff is crap!
Old Nov 13, 2010
so what to use instead of WLG
Old Nov 13, 2010
Regular grease!
Old Nov 13, 2010
Thanks for the advice. I will give it a try and see if it works.
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Jrosa
Sep 14, 2015 08:24 PM
czarlun
Sep 14, 2015 08:16 PM
