Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
D16A8 engine help
Old Nov 15, 2013
Full Throttle's Avatar
Full Throttle is an unknown quantity at this point
D16A8 engine help
I have a 94 civic coupe. I got a engine from jdmtigerjap.com ZC DOHC 92-95. says its a D16A8. I herd that engine is hard to get parts for. im new to Hondas. but any info of what car I get parts for if I just walk into the parts store needing a water pump, sparkplug wires, gaskets, etc ..normal maintenance stuff or the parts that interchange with this motor. im wanting to change a few gaskets and belts before Install. any help will be appreciated.
Old Nov 16, 2013
Re: D16A8 engine help
Don't know what is interchangeable, sorry... Reason - see where this engine where applied - europe or australia:
D16A8
Found in:
1988-1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992-1995 Rover 216/416 GTi(UK/Europe)
1993-1997 Rover 216 SportCoupe (Europe)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 × 90 mm (3.0 × 3.5 in)
Compression : 9.5:1
Power : 120 hp (90 kW, 127 ps) @ 6800 rpm
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 5900 rpm
Valvetrain : DOHC (4 valves per cylinder)
Fuel Control : OBD-0 MPFI
ECU Code : PP5
Gearbox : L3
note:
I am moving your thread to the 5th generation forums, you posted on the current civic forums, quite newer than yours.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
