Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
First swap, plz help
Old Oct 4, 2012
Espey94ej's Avatar
Espey94ej is an unknown quantity at this point
Exclamation First swap, plz help
Im doing my first motor swap on a honda.
i have a perfectly running 1995 acura integra ls 5speed with a b18b1. i want to take the motor and tranny out and put it in a civic shell. either a late 90's hatch. or a 5th gen civic coupe, or hatch.
shell meaning, gutted, nothing on or in it, i want to build it from ground up.
with that said, when taking the motor out of the acura what all do i need to remove for this job.
thanks for viewing, and please be patient like i said this is my first time
thanks again. austin
Old Dec 19, 2012
Chris1327's Avatar
Chris1327 is an unknown quantity at this point
Re: First swap, plz help
This isn't a swap, it's a custom install. if your throwing it into a shell you will need the wiring harness etc, but there's no reason you couldn't just use all the stuff from the integra engine. Although, I would rather use a Legend engine, more cylenders, more HP.
Acura is Honda, don't forget that.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Solo Flow
Oct 4, 2015 07:52 AM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Luluharp
Sep 27, 2015 11:56 AM
