Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
turboing a d15b vtec-e engine
Old Jul 26, 2010
steve93civichb's Avatar
steve93civichb is an unknown quantity at this point
just wondering if i should upgrade the engine. or if this one is ok for stock internals for the boost i am going to put on it.
Old Jul 26, 2010
SlammedZChatch's Avatar
SlammedZChatch is an unknown quantity at this point
Re: turboing a d15b vtec-e engine
how much boost do you want to push on it?
Old Jul 27, 2010
6 psi. just a little but, is that a good engine to turbo? if not i wanna do a swap
Old Aug 8, 2010
Nitrous1024's Avatar
Nitrous1024 is an unknown quantity at this point
You can safely do the 6PSI
If you want to do a swap, a B16A, B18C, or K20 will require matching gearbox and a new ECU (with wire-loom).
I'm contemplating such an upgrade myself.
Old Aug 8, 2010
02civicsi02's Avatar
Low and slow!
I would say 6psi should be safe with stock internals but any more and the head will not be able to handle it. It all depends on your plans. You are wanting to turbo to get some power. But eventually you will want more because if you want to turbo then you will want more power eventually and the best thing to do is swap really it would save you alot of money in the long run. But always remember there will always be a faster car out there. It all depends on what your plans are on what you want to do.
beneditti
Jan 15, 2016 12:31 PM
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
mikevtec
May 3, 2015 01:36 PM
cloudguy
Apr 28, 2015 05:02 AM
CapYoda
Nov 11, 2001 05:17 PM
