Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
I need an affordable quailty turbo kit
Old Feb 15, 2009
jaysuper's Avatar
jaysuper is an unknown quantity at this point
Talking I need an affordable quailty turbo kit
Hi guys I'm looking for a turbo kit for my 92 HB I have a single cam zc with a d16y8 head does anyone have a suggestion on what turbo kit I should get. I'm just looking for something for a everyday driver reliability is more important than hp and I want to keep it under 1200 dollars. And I know I can swap for about that same amount of money but I want a turbo thanks guys.
Old Feb 24, 2009
StardustLily's Avatar
StardustLily is an unknown quantity at this point
Re: I need an affordable quailty turbo kit
Are you sure you want to go turbo then? No matter what size of turbo and what level of boost you add, you always absolutely murder reliability and gas mileage. Also, a good turbo will cost 500-600 which leaves you almost no room for all the other essential parts or the labour required. So I dunno if turbo is a good road for you given your budget. I have however seen turbos for like, 250-300 but I REALLY question their reliability...x.x
Old Mar 1, 2009
Mitchell_2kSiR's Avatar
Mitchell_2kSiR is an unknown quantity at this point
my fuel mileage is the same most times better than when i was N/A. . its all about the tune. . . if i'm in boost all the time yeah i'll get about 30-40km's less on my tank
Old Mar 2, 2009
Boilermaker1's Avatar
Jap-Euro Fusion
some people have actually seen gas mileage increases with turbos... so I wouldnt go as far to say you're going to destroy your mileage.
For 1200 bucks you wont find a complete kit, new and worth buying. At least double it. If you're looking in the $1200 range, I'd suggest scanning the classifieds for a used kit, and either sending the turbo out for a rebuild, or buying everything but the turbo, and buying an already rebuilt turbo (which is less than a new one but every bit as good).
Old Apr 29, 2009
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
I had great gas mileage when I was boosted a few years back. I shouldn't have tuned it for 94 octane mind you, but the mileage itself was almost as it was when the car was stock. Reliability is an entirely different issue. I made it to the two year mark of daily driving / occasional track abuse before my little D17 gave up. Not bad for a stock motor with head studs / head gasket I guess.
Old May 1, 2009
D17alltheway's Avatar
D17alltheway will become famous soon enough
you can start with buying my stuff in the FS thread....its a start.. but Boilermaker is right if your gonna cheap out i hope your doing 95% of the work and would know how to fab up your own stuff but other than that you'd have to settle with at least a 2500 budget and in most cases.. depending on goals... engine management isnt even included... but i heard from the guys who've made monster numbers... and if your gonna boost.. take your time and do it right the first time so that it becomes your only time
Old Oct 9, 2009
r6raven08's Avatar
r6raven08 is an unknown quantity at this point
yall are stupid the turbo was designed originally to improve gas mileage along time ago not for tuners a tuner beafed hid up and started the revolution
Old Oct 9, 2009
expect to spend 4500 for a decent turbo setup and another 4500 on repairs after the install as stuff starts to fall apart.
HondaGuy7
Feb 22, 2016 01:00 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
