95 civic headlight connector problem
Old Feb 18, 2013
velozp's Avatar
velozp is an unknown quantity at this point
Hi all I have a 95 civic. My drivers side low beam was very dull. When I went to check it out, the connector that plugs into the bulb is melted. Also the ground wire basically broke off the spade lug. I did see some info on the web that if you use H4 bulbs, it can cause the connector to melt. Is this true?? The stock bulb is the 9003. IS this a common issue with these cars? Maybe I do have the some type of hi performance bulbs in it, I bought the car used. The passenger side also looks like it may be starting to get slightly melted also. Any advice? thanks to all
Old Feb 18, 2013
Re: 95 civic headlight connector problem
You can purchase replacement pigtails (socket with wires) for most types of headlight bulbs at almost any parts store......even DangerZone.
Ebay: http://www.ebay.com/itm/2-pcs-High-T...-/130426989207
DangerZone: http://www.autozone.com/autozone/acc...er=767899_0_0_
HTH
Old Feb 24, 2013
velozp's Avatar
thank you the new pigtail worked, I soldered it on, got the wiring diagram from this site, thanks
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
15
Aug 19, 2015 03:12 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
bsmiley
Apr 27, 2015 01:27 PM
CivicBR900EX
Sep 5, 2001 10:27 PM
