Simple job, not so simple?
Old Feb 6, 2011
Gsxrman's Avatar
Gsxrman is an unknown quantity at this point
How's it going, bought a 1993 Civic good shape just has one working rear speaker. I bought a replacement set tried to install a front speaker and couldn't get any sound from it. I wired the blue to the positive speaker wire, and the gray to the negative. Took some pics, in the attachments. I've just switched from domestics, heard imports where easier to work on what's the deal Thanks for any help.
ID:	80216   Click image for larger version
Old Feb 6, 2011
Re: Simple job, not so simple?
radio might be messed, or the wiring
Old Feb 6, 2011
Gsxrman's Avatar
Thanks for the reply. So I could have a bad radio, that only goes to one speaker? If it's not the radio, where would I follow the wires to to find the source of the problem?
Old Feb 7, 2011
TRIZ's Avatar
Does the radio power on? If not, bad radio
Do you have voltage at the end of the speaker wire when the radio is on (via voltage meter)? If not you have a bad connection, trace the wire from the speaker back to the radio, something isnt connected in between. You'll have to pull some interior pieces off but it'll be a good job to figure out where stuff is in your car. Good thing you have an older one, the newer they are the more wires they seem to cram into our cars.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
lowlife9
Oct 6, 2015 04:39 PM
ken4444
Sep 30, 2015 07:37 PM
carid
Sep 28, 2015 10:13 AM
