Notices
Tire rub on lowered '93 civic EX
Old May 26, 2012
Freek21's Avatar
Freek21 is an unknown quantity at this point
Hey Guys,
I have a '93 civic EX that has been lowered, not sure how much or what brand kit was used. Both my front tires rub at full crank I am pretty sure in both directions.
Now I know that a lot of the issue on the right side is that the lower control arm is bent. Think the guy before me noodled a curb at a decent speed and the tire sits back at least half an inch on that side, but the left side seems to rub as well.
I'm running 195/55 R15's there is also a stamp on the inside of the rim that reads 15x6.5 JJ. Now I'm not sure of the offset but I measured from the inner edge of the rim to the mounting plate and it comes out 5.5". I think that comes out to a 1.5" positive offset or 38mm.
My question really is am I running the right size tire and offset and is there something that would give me better performance and not rub?
I don't really care for the look of the wheels I have now and the rubber has been cooked off as well, I want something that is a bit more even with the outer edge of my fenders.
Thanks.
Old May 26, 2012
Re: Tire rub on lowered '93 civic EX
why are you thinking about tires and wheels before thinking on the bent arm?
Old May 26, 2012
Freek21's Avatar
I am not thinking of the bent arm because I already know it is an issue. I have the part for but just need to do the install. Do you think that might clear up the left side rubbing as well?
Old May 27, 2012
try it first, then align, if not solved, come back here
hewey23
Suspension
Sep 4, 2022 07:58 AM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
EvilTwin
Nov 8, 2001 12:17 PM
DC5@EM2
Nov 4, 2001 08:42 PM
