ebrake does not engage on passenger side
Old Apr 30, 2022
blackdog48's Avatar
blackdog48 is an unknown quantity at this point
Hello CivicForums,
I am also having a problem with my emergency brake. It engages on the driver side rear wheel but not on the passenger side. I checked the lever and spring in the drum assembly and everything looks good. What I do see happening is that the little metal part that houses the adjuster nut behind the console is cockeyed. I have included an attachment to show this. Also, in the photo I have circled the little nipple where the cable begins. This little part moves in and out a bit on the passenger side, but it does not move on the driver side. Any idea what is going on here? Pulling on the cable
does not make it move, so I assume it is not broken. Thank you,
Andrew
Old Apr 30, 2022
Colin42's Avatar
Re: ebrake does not engage on passenger side
Probably a bad cable, disconnect it from the handle and see if you can get the cable to move
Old Apr 30, 2022
blackdog48's Avatar
Thank you for the response Colin42. I was able to remove the end cylinders of both cables from the cable housing (equalizer?). The one that works is a bit more taught than the one that is not working, but the difference is fairly subtle. There is cerrtainly not a lot of sloppiness in the non-functional one. Tomorrow I will look at what happens inside each brake assembly when the cables are pulled. Perhaps that will shed some light on things. For now, any other ideas of what could be amiss? Thanks again,
Andrew
Old May 2, 2022
BrotatoChip's Avatar
Super Moderator
If a cable isn't seized inside its plastic/rubber casing then you'll need to start looking at the actual brakes.
Old May 2, 2022
blackdog48's Avatar
That is what I thought BrotatoChip. So, I'll fix it next year when I change the pads. Thanks,
blackdog
Stephanie Simon
May 17, 2021 06:35 AM
gtrvsm3
Mar 10, 2009 06:40 PM
gearbox
Wheels and Tires
Jan 28, 2009 04:41 PM
Transformer_Guy
Nov 6, 2007 11:14 PM
joescivic02
16
Oct 7, 2004 09:22 PM
