Notices
Wheels and Tires Post your wheel and tire related questions here.
big problem with rear brakes adjustment
Old Jan 28, 2009
hey guys my rear is up on jackstands im trying to adjust my ebrake which right now barely keeps the car from rolling at a stop. i read the manual but ran into a problem right away. even with the adjusting nut in the console totally loose, my driver side rear wheel has drag when i spin it! the other side is fine. so im stuck what to do now?
Old Jan 28, 2009
greeen01civic4d's Avatar
Re: big problem with rear brakes adjustment
its supposed to have a slight drag when u adjust it
Old Jan 28, 2009
no its not actually, per the service manual. its supposed to have slight drag when park brake is pulled one click. when released, should be no drag. there is no drag on the passenger side wheel. only drivers side and i forgot to mention, its not a constant drag, you can hear where it scrapes one or two places as the wheel spins once. i think the drum might be out of round or something. also before i started, i did the brake self adjust by loosening the cable, starting the car, and pressing the brake pedal several times. then i adjusted the park brake. which by the way is still almost useless. i have to pull up as hard as i can and the car barely starts to slow down. if i was going 35, it would prolly take almost a mile to bring the car to a stop. you almost cant feel it doing anything. yet its tightened exactly like the service book describes. and it clicks 6-7 times.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jakeconnor
May 5, 2015 07:30 AM
bsmiley
Apr 27, 2015 01:27 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
