sputtering
sputtering
Hey guys I have a 95 civic DX one day they car was running fine and the car suddenly shut off it cranks up and drives but after awhile it wanna die and shut off so I have it keep gassing it so it won’t stall like it’s not getting any gas
Fuel filter?
fuel pump?
Injectors ?
Need help
Fuel filter?
fuel pump?
Injectors ?
Need help
Re: sputtering
Maybe water in the gas (rare) at the last gas station you visited?
Maybe fuel pump is weak/intermittent?
Poor sparck due to failing ignition coil?
Try disconnecting the fuel return (rubber house) at the FPR (fuel pressure regulator). Use a clean,dry bucket to catch the fuel, have a helper turn ithe ignition to position two and pay attention to the fuel flow making sure it's even and not spitting out air. Afterwards check the gas in the bucket and see if there's any water in the gas (it should separate)..
Test the ignition coil as shown in the video at the bottom of my reply (in my signature).
TutorialSurplus
16
Jan 25, 2017 09:01 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
Guillen21
Jul 27, 2013 11:12 PM
atroutslayer
Nov 5, 2012 06:41 PM
