Engine Knock
Old Nov 30, 2019
ykf7b0's Avatar
ykf7b0 is an unknown quantity at this point
Engine Knock
I have a newly built d16a6 and after a complete warm up with idle rpm's (750) I'm hearing a knock. Oil pressure at warm idle is 25 psi (75 psi+ at highway speeds) and the knock seems to be up top the best I can tell with my stethoscope. I have re-torqued the rocker shaft hold down bolts and valve lash is correct. I have 2200 miles on the fresh rebuild. I believe the knock is oil pressure related and at this point I don't believe it is rod knock because with a slight increase in rpm (900) the noise disappears. I think maybe it could be excessive clearance from the rocker bridge or the cam cradle and these area's are expanding with the engine heating up. ? Anyway, I would like to get your thoughts on this issue please.
Old Dec 15, 2019
ykf7b0's Avatar
Re: Engine Knock
Anyone?
Old Dec 16, 2019
BrotatoChip's Avatar
Super Moderator
Re: Engine Knock
Does the oil have metal flakes in it?
Old Dec 16, 2019
ykf7b0's Avatar
Re: Engine Knock
None.
Old Dec 17, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Engine Knock
-1 bottle of Lucas HD would be your best bet, temporarily, until you find the issue.
I've run it in hundreds of cars. It's great for burning and knocking.
Old Dec 18, 2019
ykf7b0's Avatar
Re: Engine Knock
I like Lucas too and have added some but noise remains.
John Mayfield
Aug 30, 2019 08:53 PM
Squeeken
Jun 11, 2013 12:03 AM
hcivic86
Dec 3, 2011 03:19 PM
DerekxxCore
Jul 24, 2011 06:03 PM
krazymatt
Jan 10, 2010 10:53 PM
