Tps replaced high idle
Old Jun 8, 2019
Doug Wagner's Avatar
Doug Wagner is an unknown quantity at this point
I have a modified 1993 civic that had a check engine light so i checked it out and it was for the throttle position sensor. Assuming it was bad i replaced it and now on start up is at 2000 rpm to 3000 rpm. I tried the ecu reset thing where you remove the fuse to the ecu and disconnect the battery but that didnt work. Any advice?
Old Jun 12, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Tps replaced high idle
Did the issue only start after your last modification? In which case what was modified?
Old Jun 12, 2019
What exactly did you calibrate (adjust) your new TPS to??
(IIRC it may need to be 0.49v at closed throttle)
ZweedNaat
Dec 23, 2017 11:49 PM
Lordsin
Apr 12, 2013 10:32 AM
the1djones
Oct 10, 2012 11:29 PM
magic_wizard
Jul 5, 2006 01:41 PM
Zigen1
Jan 22, 2003 06:33 PM
