radiator problem
Old Apr 12, 2018
Nguyen-ing's Avatar
Nguyen-ing is an unknown quantity at this point
radiator problem
okay so I had a minor incident ended up bending what is in the circle. Can someone give me a name to what this part is trying to either fix it or replace it so my radiator can fit the in the bottom cushion. Also this is not my car just couldn’t find a better image.
It’s bent upwards probably about 2 inches or so.
P.s my hood won’t shut all the way, but it does lock down can this be the cause of it also. Thank you in advance.
Old Apr 12, 2018
Re: radiator problem
I'd call it a "core support"
Honda probably calls it 'crossmember, front bulkhead (lower)' or something similar
If it's not seriously mutilated, only bent up:
Remove radiator
Use a long block of wood and a hammer to pound the bent piece back into place.
cyprosoft
Nov 6, 2017 02:41 PM
tavisc
Mar 6, 2015 06:30 PM
Civic_Nightmare
Sep 8, 2011 12:16 AM
mrDFWmechanic
Engine Swaps
Nov 28, 2005 10:45 AM
Brian2MN
Feb 3, 2003 11:36 AM
