Won't shift out of 1st in D3 and D4 now matter how high it revs
Old Oct 3, 2014
Strikereleven's Avatar
Strikereleven is an unknown quantity at this point
Exclamation Won't shift out of 1st in D3 and D4 now matter how high it revs
I just got this 95 civic about a month ago and since I've had it I haven't been able to get it into 3rd or 4th gear. 110k miles, automatic, the motor runs beautifully, and all the electronics seem to be in order. However, when I drive it 1 and 2 on the console work as they should, but when I shift into D3 and D4 the car will not shift past 1st gear. When I drive on D3 or D4 in 1st once I get going to say 30mph I can let my foot off the gas and the rpm drops down, then if I press the gas again it acts like it is in neutral until I hit about the 3k rpm mark and the converter will engage again.
That is the story and now here is what I've found out so far:
No engine codes (Jumped the OBD I plug and found no codes)
TCC/Shift solenoid pass resistance, power on tests, and the screens were clear (15 ohms on each side and solenoid clicks with 12v applied)
I've received a citation for out of date inspection and need to get this fixed to pass the treadmill, please help.
mistahlorax13
21
Nov 18, 2015 12:47 PM
danace99
Oct 17, 2015 02:51 PM
winanthony94
Sep 25, 2015 09:05 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
