95 DX Hatch Won't Idle
Old Sep 14, 2014
42vagabond's Avatar
42vagabond is an unknown quantity at this point
1995 Civic DX Hatch. Car started to idle rough now will not idle at all. It appears to be flooding. Replaced EACV and disassembled, cleaned and reassembled Fast Idle Valve. Removed Throttle Body and cleaned. Installed new sparkplugs and PCV Valve. Still will not idle at all. Runs fine on the road. I can smell fuel and if I remove the brake booster vacuum line and meter the open end the engine will idle although higher than normal. This leads me to think its running rich. Sorta lost now. Cleaned the MAP Sensor plug. Think it could be the O2 Sensor? No Engine Codes.
Old Sep 14, 2014
42vagabond's Avatar
Re: 95 DX Hatch Won't Idle
Also when the car stalls it takes a lot of cranking to start it and will only start if the gas pedal is on the floor while cranking.
Aball93
May 16, 2015 10:11 AM
Supramk3
May 11, 2015 07:55 PM
2k2civic
Feb 6, 2002 06:08 PM
FiresVTEC
Jan 21, 2002 02:34 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
