Idle/Check Engine
Old Sep 21, 2014
thedude7238's Avatar
thedude7238 is an unknown quantity at this point
Idle/Check Engine
Ok, So I am getting ECU code 14 (IACV). As I've taken it in and out to clean it, I've unplugged the wires to it, and somehow or another also unplugged a wire next to it off of a vacuum line, and they are the exact same, and not sure which one goes where. One is grey, one is white, put both fit on either connection. And since I have been having idle trouble for a long time now I'm not sure how long ago i made the mistaken wire swap. So any help would be great.
Does the white one go to the IACV or to the vacuum lines?
Thanks
Old Sep 22, 2014
Re: Idle/Check Engine
Swap them and see what happens
Old Sep 22, 2014
I have swapped them around, and messed with the idle. The problem is that I messed with the idle before I realized that I might have swapped them on accident. I'm hoping someone will will go look at the plug on their IACV and tell me what color it is. white or grey?
Old Sep 22, 2014
My wire diagrams have
IACV, gray, wire colors yellow/black and blue/yellow
EVAP Purge solenoid, gray, wire colors yellow/black, and red
IAT sensor uses white connector, red/yellow and green/white
Old Sep 22, 2014
Thank you!
Old Sep 22, 2014
Oh hey I was looking at a diagram for a 92 car. Izzat right?
Old Sep 22, 2014
Yes perfect, thanks again
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
