AC idling issues
Old Jul 25, 2014
thedude7238's Avatar
thedude7238 is an unknown quantity at this point
AC idling issues
Well I have had a bunch of recent issues with my 1992 Civic LX, but the only one really bugging me is the idle. Shouldn't the engine idle up when the AC is turned on? My older (1988) civic used too. What sensor or valve is in charge of this operation?
Old Jul 25, 2014
Re: AC idling issues
The idle doesn't necessarily have to increase, it depends on programming.
It SHOULD stay at a consistent RPM as the compressor engages and disengages. It shouldn't drop a bunch when the compressor kicks on.
The 88 may have used vacuum diaphragms for idle-up RPM control that were independently adjustable.
The 92 is not the same, it should use an IAC to control idle speed, as determined by the computer.
HTH
Old Jul 26, 2014
OK... where is the IAC? Right now when the AC is turned on it idles at about 100 and dies at stop signs.
Old Jul 26, 2014
SWAG at what car you have, for a catalog pic:
Box #17 is the IAC, bolted to the back of the intake manifold with 2 bolts. Just remove the bolts and lean the IAC back for access (I don't disconnect the hoses).
#19 is called a filter.
This probably has the filter screen clogged with carbon and soot buildup, clean (scrape) the buildup off of that screen out see if that helps.
Then you might want to clean out the throttle body.
HTH
Old Aug 10, 2014
Rhonda1's Avatar
Rhonda1 is an unknown quantity at this point
Don't forget to bleed the air out of the coolant because that will will also cause the IACV to act up.
The Big Dutch
Jun 9, 2015 07:49 PM
Bradel26
May 30, 2015 10:24 AM
Allecr3
May 22, 2015 01:24 PM
crowtoo
May 11, 2015 06:50 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
