transmission
Old Jan 8, 2014
bacascooby's Avatar
SOUTHERN SLEEPERS CAR CLUB WACO, TX
bacascooby is an unknown quantity at this point
transmission
OK so I sold my civic and picked up a 93 prelude si for 700 bucks. I tot the car because the person I got it from said the clutch was going out. Its not going out its doesn't want to go in gear some times when its running. I can bleed it and go about my way till it starts again in the next day or so. I replaced the master and slave cylinder. Through out bearing isn't making noise and the when everything's shifting good the clutch will ****** and grab with no problem. I'm getting air in the lines some how everything thing is tight on master and slave (line wise). Fluid isn't leaking anywhere could I still be sucking air in the lines if I'm not losing fluid and where at.
Old Jan 9, 2014
Re: transmission
Does air come out when you bleed it?
Is fluid disappearing?
Can you describe how the pedal 'feels' when this happens?
Ummmm..........
Have you checked the pedal pushrod, make sure there is some clearance --- make sure there is free play at the pedal before the pushrod makes contact with the master cylinder? Probably needs about (guess) a half inch of free play at the pedal
Old Jan 9, 2014
bacascooby's Avatar
Re: transmission
Air does come out when I bleed it. I even bought a vacuum pump to pull the fluid and air through the system to help bleed it. Its like I get the air out and then more enters the system some how and there isn't ever a lose in fluid. That's what's making this a pain. If the fluid was leaking thats the air would be getting in.
Old Jan 9, 2014
Re: transmission
I have no idea why air would get in.......
If this is a new problem just since you replaced the slave and master, maybe one of the parts you bought is defective somehow?
For the original problem of not wanting to go into gear, I was thinking if the clutch is releasing completely (hydraulics working correctly) yet still can't go into gear, maybe a pilot bearing bad or the disc hanging up on the splines of the input shaft.
Old Jan 24, 2014
iim1rmg's Avatar
iim1rmg is an unknown quantity at this point
Re: transmission
If you are getting air when you bleed, it has to be:
1. Slave cylinder
2. Master cylinder
3 Hydraulic line or connector.
New does not eliminate the possibility of bad (I had a new MC from China (NAPA brand) that sucked air), but I would first take a good look at the line between the two. Look for hairline cracks and pin holes.
You said there were no leaks, but did you check inside the car? Especially where the MC rod comes through the firewall?
Old Feb 8, 2014
ant3198's Avatar
ant3198 is an unknown quantity at this point
Re: transmission
i know this thread is old but i have a 01 civic ex canada based.... i got a free jdm tranny from a friend but cant put it in bc it will THROW A CEL FOR CODE P0740 AND CAUSE PROBLEMS WITH THE TCC....question is that i replace the computer would i be able to use the jdm tranny in my canadian hond?
i never work on cars so im lost
Old Feb 8, 2014
Re: transmission
How do you know this?
Re-read your post, see what handy information is missing from it.
Old Feb 8, 2014
ant3198's Avatar
Re: transmission
bc i went on the jdm website and it say that i cant switch it into canadian...what info am i missing???...im just looking for some help bc like i said i know ****
Old Feb 8, 2014
Re: transmission
My first thought was that maybe you are trying to swap a manual to an automatic or something. I had no idea.
I primarily deal with mostly stock cars in the USA.
I'm trying to wrap my head around a JDM trans that is already known to cause codes....
Why did said friend get rid of it?
What is so vastly different about this JDM transmission that it will cause this certain code?
If they say you can't put it in a Canadian car, find out WHY... And ask what cars CAN it be installed in?
Seems to me like this would be a question best asked of the JDM people that told you it can't be used in your canadian hond.
You better also ask them what a JDM computer is going to do to the immobilizer system in the car, and find out if your local Honda dealer will still be able to reprogram your keys to it.
Then find out how much that programming will cost at your local dealership.....
Plus the tow truck fee to drag it there.
IF your car must pass an emissions test, a non-stock computer might cause you to fail. Check your local regulations.
If it wasn't right for the car in the first place, FREE isn't going to make it work any better.
Sometimes FREE isn't worth the price.
But it's up to you to decide that.
HTH
Old Feb 8, 2014
ant3198's Avatar
Re: transmission
Oh its just a jap based d17 5 click tranny
Old Feb 8, 2014
Re: transmission
Again:
Ask the JDM people that told you it can't be used in your canadian hond.
HTH
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
C-Hamm
Sep 28, 2015 10:31 PM
Elciteeve
Sep 28, 2015 12:40 PM
jerry38
Sep 20, 2015 08:38 AM
