D15B7 timing belt confusion.
Old Dec 18, 2013
wastintime's Avatar
wastintime is an unknown quantity at this point
Hey everyone,
So, first of, I apologize if this has been asked before, but I've been searching for hours and can't find a specific answer to my question. Especially as it applies to this specific year car / motor. There are a lot of general write ups, and even a few posts complaining about the timing marks being confusing, but I haven't really found a solid answer for this. Secondly, I'm not new to doing timing belts, I've probably done hundreds of them mainly on Porsches, Mercedes, and other German cars. Which is why it's so frustrating that a Honda has me stumped. I know this has to be done constantly on a daily basis, but this belt has been kicking my butt and I don't want to put it back together with the wrong timing.
Ok, so It's a 1994 Civic DX with a D15B7. Not that I think it matters, but it has just shy of 300k miles. Set it to TDC before pulling it all apart. Don't get me started on the pulley bolt, but anyway... got the old timing belt off, and replaced the water pump, but I am now very confused about the timing for the new belt.
Before putting the new timing belt on I decided to confirm the timing was correct. To me it was not correct. I say that because when the TDC mark on the pulley was lined up the 7 o'clock timing line on the camshaft pulley wasn't lined up with the arrow. I also noticed the crank timing belt sprocket's notch wasn't lined up with the arrow on the engine once the lower timing cover was out of the way.
The timing marks on the cam sprocket at 3, 9, and 7 had been bothering me so I asked a friend who's a tech at Honda which is the most important to line up since it seems to me eyeballing it that if 7 is lined up 3 and 9 can't possibly be lined up. I think this diagram even confirms it: http://repairguide.autozone.com/znet...52800617db.gif
As far as I can tell the cam timing marks cannot all be lined up, you either line up 3 and 9, or 7. Is this correct or not? It's further confusing because of the very poor wording of the instructions that came with the new belt tensioner. It seems to imply that the D15Z1 is the only motor that should use the 7 o'clock timing mark and the others should use 9 and 3. At the same time it seems to say that and that none of them should use the 7 O'clock mark. Is that correct that only the Z1 uses the 7 O'clock mark?
Next, the crank sprocket and pulley marks don't line up. There's an arrow on the motor that you're supposed to line up the crank sprocket notches (If the key is roughly 12 oclock, the notch is roughly 1 or 2 oclock).
https://drive.google.com/file/d/0B8E...it?usp=sharing
https://drive.google.com/file/d/0B8EgHJmgesekTG90WkZlYXBfczZZVXhYaS1nQlVibjdEQ29B/edit?usp=sharing
After several attempts to get the 7 o'clock cam mark and 2'oclock crank marks perfect with the new belt, I finally said screw it, it's close enough I can't get it any closer... when the 7 o'clock cam mark was dead on the 2 o'clock crank mark was off by maybe a degree or two. So I followed the rest of the tensioner instructions, set it back to TDC and put the lower timing cover and crank pulley back on (no bolt). The timing mark on the crank pulley is WAAAAY off! The timing mark on the lower timing cover now lines up about 1/2 way between the TDC mark and the ignition timing marks on the pulley when the 7 o'clock cam marking is lined up, BUT the crank sprocket it almost dead on.
How can the two timing marks be so wildly far off? Which do you follow the pulley marks or the sprocket marks? if you're following the pulley marks, how can you possibly install the belt and be sure it's timed perfectly and nothing has moved since the pulley is off?
I realize this is an old car with a lot of miles, and maybe some of the parts aren't stock, but this really doesn't make sense to me. I would seriously appreciate an answer as to A. which timing marks you should follow for the cam: 7 or 3 and 9 and the crank: the sprocket or the pulley and B. Which cam and crank marks should be lined up corresponding to each other.
Thanks in advance.
Old Dec 18, 2013
Re: D15B7 timing belt confusion.
You say 94 D15 engine but the pic says 1.6L. My pic is not the same as yours.
Verify the TDC timing mark is actually still in the correct place on the (large) pulley: Drop a long screwdriver into #1 spark plug hole. Slowly rock the crank back and forth to confirm the #1 piston is actually at the very top of its travel. If the timing marks are WAY off, the pulley may have slipped on the hub.
The crank timing gear mark SHOULD be lined up when the screwdriver says the piston is at the top (no matter what the mark on the large pulleys says).
Then line up the 2 horizontal cam gear marks with the head surface. The word "UP" should be somewhere in the upper area, not on the bottom.
From the service info:
D15B7, D15B8 engines : Align the TDC marks
on the camshaft pulley with the cylinder head
upper surface.
This means you ignore the pointer at 7 o'clock.
The 7 o'clock pointer is for other engines, not yours.
Slip the belt on and make sure the marks are still in the right place. Tension the belt, and recheck marks again.
Do you have the correct procedure for tensioning the timing belt?
On the rest, stop worrying over a degree or two.
You can only get as close as the spacing of the teeth on the belt, and that's gonna be a good 20 degrees or more timing error if you miss by a tooth.
Old Dec 18, 2013
Upper left corner should be yours
Old Jan 1, 2014
woodsjd1's Avatar
woodsjd1 is an unknown quantity at this point
you should have (maybe) 4 notches on your crank pulley...one by itself (this is TDC)...3 closer together...(these are BTDC indicators)...when correctly timed, you TDC will be in a 1-2:00 position because correct timing will be BTDC
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
